Projects Big daddy's 1960 El Camino
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Nov 18, 2020.
  1. 427 sleeper
    427 sleeper
    Are you positive that your Spinchter Valve isn't stuck? :D:eek::D
    enloe, SS327, Budget36 and 5 others like this.
  2. Lloyd's paint & glass
    No sir, but I'll get it checked
  3. saltflats
    saltflats
    from Missouri
    So is this doing it when the secondary's just open or after they have been open?
    mad mikey and 427 sleeper like this.
  4. 427 sleeper
    427 sleeper
    In all seriousness, what does it do with a heavier spring?
  5. Lloyd's paint & glass
    After they're open
  6. Lloyd's paint & glass
    It did the same thing with the purple spring, that's why I put the lighter one in it, figured as long as it doesn't bog down on the hit its good right? There's no bog. Only issue is when it hits that 5000 mark. Maybe it just is what it's gonna be and I'll just use that as the Rev limiter lmao
    enloe, bchctybob and chryslerfan55 like this.
  7. saltflats
    saltflats
    from Missouri
    Maybe a jet change up or down if we can determine if it's going to rich or to lean.
    enloe, mad mikey and 427 sleeper like this.
  8. tomcat11
    tomcat11
    You better just call the Petronix hot line. They have all the answers.:D
    enloe, J. A. Miller, SS327 and 6 others like this.
  9. Lloyd's paint & glass
    And on another note I had a pop when I turned the wheel, one of the guys i work with climbed under it while I turned the wheel and said it's the leaf springs. So I came home this morning and made these. Is this acceptable? It fixed the pop lol 20230523_125936.jpg
    enloe, VANDENPLAS, mad mikey and 4 others like this.
  10. Lloyd's paint & glass
    The secondaries has the stock metering plate in it. I've got a quick fuel plate that i can stick in it that uses jets in the rear. Iirc i put 72's in the primary
  11. Lloyd's paint & glass
    This is a pertronix flame thrower coil, but the distributor is the $239 speedway selection lol. If I had a rotor ****on, cap, and wires I'd put the point setup in it. I don't have much time between a body shop, an upholstery shop, and a fire department job to get much done before Saturday though.
    enloe, VANDENPLAS, mad mikey and 2 others like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    When it’s over get yourself an iron points distributor.
  13. saltflats
    saltflats
    from Missouri
    I remember you having gel problem with the carburetor, did the metering plate get cleaned good?
  14. Lloyd's paint & glass
    Well the plan for my new points setup is to go in the big block
    enloe, chryslerfan55 and scotty t like this.
  15. Lloyd's paint & glass
    Yeah I think so myself. I cleaned everything with brake kleen and blew it all out. Used a tip cleaner on everything I could. Wonder if a little seafoam would do it any good?
    VANDENPLAS and chryslerfan55 like this.
  16. Lloyd's paint & glass
    Good place to store secondary springs :D 20230523_134911.jpg
    VANDENPLAS, mad mikey, SS327 and 5 others like this.
  17. Buddy Christ!
  18. kls50
    kls50
    Might also save the little fella if he falls off the dash and lands on his head!
  19. alanp561
    alanp561
    Found an article on strengthening exercises for your **** sphincter valve. Be glad to send it to you if you think it will help ;).
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No wonder. PTSD has him thinking…
    enloe, alanp561 and chryslerfan55 like this.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    you pulled the HEI out of it??
    chryslerfan55 and enloe like this.
  22. Lloyd's paint & glass
    Yes. The weights were so worn out that they were climbing over each other. It's got this in it now. 20230523_110458.jpg
  23. Lloyd's paint & glass
    Drove it up to the machine shop to hang out a few minutes, Jamie said to fire it up tonight and see if I can see any fire jumping from the coil.
    enloe likes this.
  24. Moriarity
    Moriarity
    SUPER MODERATOR
    hmmmmm... If that is the one you got from me, I usually run them to about 6500 checking for point bounce...I suppose if they are floating a guy could put a set of Mallory or accell points in it...
    chryslerfan55, enloe and VANDENPLAS like this.
  25. 51504bat
    51504bat
    Coil wire is the wrong color:cool:
  26. Lloyd's paint & glass
    No sir it's not the points setup. It's an aftermarket speedway distributor
  27. Lloyd's paint & glass
    I knew it! I'll paint it and try that :p
  28. Budget36
    Budget36
    Wait!!!!!
    I think I have an old set of yellow wires, you’d then be color coordinated!
  29. Budget36
    Budget36
    Thinking about it, somewhere I have a “normal” looking yellow coil too. If you act now on this limited time offer, you’d fit right in with all the cool kids.
    PS
    -no guarantee that anything I have will work or fit for your application, additional charges may be incurred. This is not an endor*****t or remedy for any medical condition, some inclusions may apply. Use at your own risk-
  30. Lloyd's paint & glass
    I told you to stop drinking the bong water brother!! That **** will rot your brain cells :p:D
    bchctybob, kls50, SS327 and 4 others like this.
