Hot Rods Big Daddy's 55 2 door wagon gasser
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 1, 2024.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    put it in first gear and see how many times you have to turn the input shaft to get the output to go around once. Some of those T10's had a pretty deep first like 3:1, if so you could get by with 3.0 gears in the rear
  2. Lloyd's paint & glass
    Yeah it's got a low first gear.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    check it and report back..... when you get a chance
  4. Moriarity
    Moriarity
    SUPER MODERATOR
    ***uming a close ratio trans (2.20 first) and a 4.11 rear gear would give an overall ratio of 9.042.
    If you have a wide ratio trans with maybe a 2.88 first and a 3.0 rear it would be 8.64 so, pretty close plus you will have the big block grunt to help out. best of both worlds
  5. 38Chevy454
    38Chevy454
    I just checked the rearend is a tad under 3 turns, likely a 2.93 ge****t. It will work with big block, until Lloyd can get a better ratio. Lloyd is also getting a spare center section casting he can work on gearing and then just swap the center out. So if anyone has some gears or spool/posi carrier let Lloyd know.
    Terry's house of rearends. Wait that might be taken wrong, LOL
  6. Lloyd's paint & glass
    You're the man Terry :cool:
  7. lumpy 63
    lumpy 63
    My friend Bill had a side gig of building and selling ford 9 inch rear ends...He had a sticker on the back of his truck that said 9 INCH BILL and his phone #.... He got a few interesting calls over the years:p
  8. Black Panther
    Black Panther
    from SoCal
    Lloyd...you have a trans already I take it...but I like those late T10s..like 1979-81 or so...some have really deep first gears...as low as 3.42 1st. Some came aluminum case..the later ones cast iron. Iron is preferable of course for strength. It allows tall rearend gears for easy highway cruising and still gives you a first gear mechanical advantage poke... I have an over the counter Power Brute version of that trans..they were sold at speed shops and I wouldn't sell it for any amount of money. Cast iron case..high nickel gears...nearly indestructible.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    what is the width? Wheel mounting surface to wheel mounting surface .
    chryslerfan55 and 427 sleeper like this.
  10. Black Panther
    Black Panther
    from SoCal
    Count the rings on the input shaft....here's a chart..
  11. Black Panther
    Black Panther
    from SoCal
    The 9.3 is an awesome rearend...happy you're using that instead of that later deal.....also glad my Bell Auto Parts 37 1/2 Chevy already has one in it. Probably installed in the late 60s? Looks brand new...
  12. mad mikey
    mad mikey
    FabCraft Metal Works has everything you need, and or don't need for the 9.3. That who did my entire rear. I have a thread on it on here.
  13. Lloyd's paint & glass
    Yeah I already looked at everything they have. You've obviously got lots of money Mike! :D:D:D:D I see that I can buy a ge****t for $400, and a spool for the same money. I've learned that trying to impress you guys, is very expensive, and benefits me in no way, form, or fashion lmao!!
  14. Budget36
    Budget36
    Forgot about the 454. Good point.
  15. 38Chevy454
    38Chevy454
    Not in garage, but it's fairly wide. I would estimate 62-63 inches. 62 Pontiacs were in the wide-body era.
  16. Black Panther
    Black Panther
    from SoCal
    Lloyd...so funny and so true. I love you man and have never met you other than here. I totally get why there's what 16 pages of bs and you don't have the car yet...wtf? You are one engaging dude and breathed some comedic life into this place....God bless you brother...
  17. Sharpone
    Sharpone
    ^^^^^^^^ What Black Panther says!^^^^^^
    Loving this thread, especially like your hippy, hillbilly, backwoods friend who intimidates you. You don’t look like you intimidate easily, would love to meet this dude.
    Dan
  18. 427 sleeper
    427 sleeper
    Lloyd, if that's the same 4 speed I'm thinking about, I think it from a 79 Firechicken and don't remember if it has 3 or 4 grooves on the input... I think it has 4... which makes it a 2.88 first, I think...:confused:
  19. Black Panther
    Black Panther
    from SoCal
    The '79 Firebird still had a 400 or 403 Olds...so likely would not have a low first geared trans. In 1980 and 81 when they went to Chevy 305s in Trans Ams and Z28s so they are the main source of low first geared Super T10s . They had to make up the lack of performance in the weak 305s with gearing..
  20. Cosmo49
    Cosmo49
    Lloyd = The Anti Squirrel
    BOTH guys are GREAT READING and fun in the heat or the cold of winter!
  21. Lloyd's paint & glass
    Yeah, but it seems like it has 3 grooves. It's at the old location still. Along with about 5 truck loads of parts I have to move. I have an NP833 that has a 3.09 first gear. I'll figure out what I'm gonna do when I get there. I'm thinking I'll run a 2.93 open rear until I get the other center section put together. :D
  22. 427 sleeper
    427 sleeper
    You'd probably like the 833 better if that's the case. The clutch would like it alot better too! ;)
  23. Lloyd's paint & glass
    Will the big block ring the guts out of the 833?
  24. i7083
    i7083
    It can ring the guts out of anything if you do it right...:D
  25. 427 sleeper
    427 sleeper
    Depends on what you're using for rear tire's, I guess. Let the tire's be the Fusible-Link and the rest of the driveline should live a decent life.
    I don't really have any experience with those boxes', I've always run Muncie's with mid to high 4-series gear's.
  26. Lloyd's paint & glass
    Yeah it'll never have slicks on it. Hmm
  27. wvenfield
    wvenfield
    Just for info. I have a 69 GTO rear end under my 56 Pontiac. I believe they are 61 inch, (Drum to drum).
    I have 9 inch slicks under mine without cutting the quarters. Granted, I can't remove them without undoing the rear shackles. I forget what wheel offsets I had to use.
  28. patsurf
    patsurf
    weren't they behind all big chrysler stuff?
  29. Lloyd's paint & glass
    That was the original A833. This was the latter. Chrysler owned New Process. They made the NP833, It has the Chrysler pattern where it bolts to the bellhousing, but the bellhousing bolts to a Chevy block. It's actually an overdrive transmission. It was used in Chevy trucks through the 80's.
  30. Lloyd's paint & glass
