Technical Big truck open drive
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Apr 22, 2023.
  1. oliver westlund
    oliver westlund
    Anyine know if a big truck open drive on a 3 or 4 speed uses the same trans mount and yoke as a pickup? Wondering if it'd fit on my 39 trans.
  2. oliver westlund
    oliver westlund
  3. Budget36
    Budget36
    I don’t know, maybe @Mac VP will look at the HAMB today.
    oliver westlund likes this.
  4. 38Chevy454
    38Chevy454
    Don't know about the rear mount, but the front bellhousing is the one that people use to mount a later open drive transmission behind a flathead. That is worth saving off the trans.
  5. 1952henry
    1952henry
    That is a transmission from a half-ton, I believe.
  6. 51504bat
    51504bat
    Looks like it has a place for a PTO which would make it 3/4 ton or larger if I'm not mistaken.
  7. Marty Strode
    Marty Strode
    The pickup 42-52 has a slip yoke, as I remember it interchanges with a 55-57 Chevy. So you will need the matching output shaft as well.
  8. Mr48chev
    I'm getting 13-5/8 or so depending on how I hold the tape and the camera from front of hogshead to the center of the mount bolt on the two that I have. Odd thing, the one with the PTO cover came out of a 52 1/2 ton pickup ch***is that I bought and the one with no pto came out of what was supposed to Be a "Truck" It's going in my flathead six powered speedster. the one out of the 52 Ch***is sat out in a field for over 20 years and is froze up but parts are parts. IMG_8316 (2).JPG IMG_8315 (2).JPG IMG_8312 (2).JPG
  9. oliver westlund
    oliver westlund
    I have a pickup open drive with output shaft but no yoke, thats why I was curious
  10. Mac VP
    Mac VP
    To answer the original question, the answer is no. The rear bearing retainer (which is also the rear support) has a different bolt pattern and the recess for the rear ball bearing, and snap ring is larger on the truck 4 speed transmission. If the intention is to make the 39 transmission into an open drive type, you’d need the 42-50 light duty 3 speed open drive mainshaft and rear retainer……and those pieces would only work if the 39 transmission you currently have is built with the late style synchronizer ge****t.
    Budget36 and alanp561 like this.
  11. 1952henry
    1952henry
    All of the T9 non synchro four speeds had the PTO port. This transmission was optional in half-tons.
  12. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    The larger big trucks had the emergency brake on the back of the transmission. Drive shaft brake. Different animal altogether, I'd think.
  13. 1952henry
    1952henry
    No, same transmission. The rear mount/output bearing retainer (which is removable, by the way) for the 3/4 tons, 48-early51 had no provision for parking brake drum/hardware (parking brake was in rear drums). The late 51-52 mount did. All of the large trucks had the mount with provisions. Yes, there was one T9, it was adaptable for different Ford applications through the rear mount. The one pictured by the op is a half ton mount.
    As an aside, I am using a 3/4 ton mount from a F2-F3 48-early51 with no park brake provision for my MH awd F3. Original was cracked. And MH put park brake drum on transfer case. But enough with the rabbit holes.
    Beanscoot likes this.
  14. 1952henry
    1952henry
    From number on case, I believe that to be the HD 3 speed, available on both 1/2 and 3/4 tons. They are worth saving/selling, synchronized in 2nd and 3rd, iirc.
  15. Marty Strode
    Marty Strode
    My 52 half ton had a column shift.
  16. 1952henry
    1952henry
    That would have been the light duty 3 speed.
    Cosmo49 likes this.
