Biggest Traditional V-8??
Discussion in 'The Hokey Ass Message Board' started by Piper106, Dec 12, 2010.
  1. RichFox
    RichFox
    If you had Studebaker stock before the merge, you still had Studebaker stock after the merge. And if you still have it you are doing alright. Stude didn't fold, I am told, they just went out of the automobile business. So to me it sounds like Stude absorbed Packard.
  2. Spity
    Spity
    But look who phased out first...;)
    How about a 702ci GMC v12
  3. pdq67
    pdq67
    My vote is for the 534" MEL big truck engine, but it is a great big SOB!!
    Probably 1,100 pounds worth here.
    Otherwise the later 500" Cad that can go to 550"s easy and then some more! But it's too new.
    And, imho, GMC has some great big, no more than V-6 bangers here that get really big..
    pdq67
  4. AG F/C
    AG F/C
    IHC V549 out of the box.. Big but not very big on hp
  5. FrozenMerc
    FrozenMerc
    You may be right except it has been done, and with a Cammer no less. Check out the build thread. I will grant you that he cheated and moved out to a 4.7" Bore spacing. I know it is alot easier to do with a 460 block, but the OP didn't want the 385 series to be considered.
    http://www.network54.com/Forum/74182/thread/1228703224/585+SOHC+on+the+dyno
  6. FrozenMerc
    FrozenMerc
    GMC did also have a 637 ci V8 that was in the same family as the big 12 and V-6's. I am not sure if it was pre '64 though.
  7. 64T-bolt
    64T-bolt
    from Kansas
    early 30's Cadillac 452ci V-16. .
  8. xafalcongs
    xafalcongs
    Interesting build but sure not inexpensive, even for a big buck build. Changing the BS is big bucks....wonder how he handled the rod spacing and counter weight spacing.
  9. patrick66
    patrick66
    The 413 RB Mopar block could be worked to 503 ci, IIRC. Normal 413 parts (especially pistons!) are expensive enough, so this animal these days would be a bag of $$$ to build. I'll have to see if I can dig out the magazine article that described this, I remember reading about it years ago.
  10. RichFox
    RichFox
    And combustion chamber spacing? And valve guide spacing? And cam lobe spacing? Sounds like he just built a new engine that looks a lot like a Cammer.
  11. Mike B
    Mike B
    Maybe not the biggest, but we can't forget the 425 Buick Nailhead.
  12. stainlesssteelrat
    stainlesssteelrat
    from ms
  13. seb fontana
    seb fontana
    from ct
    1,100...:d
  14. mechanickeith
    mechanickeith
    Friend of mine here in town has a 59 Pontiac 389 that he has bored & stroked to 577CI. Added 2" to the deck & a 4.8" stroke.
  15. FrozenMerc
    FrozenMerc
    Here is a thread that better explains Jay Brown's 585 ci Cammer.
    http://www.network54.com/Forum/74182/thread/1250519404/585"+SOHC+on+the+dyno
    I would be interested to know how much cash he has in this motor. Definetly not cheap, but a very unique build none the less.
  16. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
    What about BB mopar??? Came out in 1958. 426 was the largest you could get before 64. You could dress up a stroked 440 easy over 500 ci.
  17. RichFox
    RichFox
    WOW! Not cheap may well be the understatement of the day. Interesting engine. But seems to have been built with no Ford parts. So I'm going to stick with my description of it looking like an SOHC. Kind of like those Falconer offshore engines that sort of look like a BBC but are actually longer, taller and wider and lots bigger inside. I am still thinking the 805 Roline was the biggest OHV V8 I saw mounted in a road going vehicle in the '50s. Never saw one in a car. Way heavy but maybe not worse than the GM V12
  18. 3Kidsnotime
    3Kidsnotime
    from Utah
  19. Truckedup
    Truckedup
    Military M123 10 tons and some 50's road trucks used a LeRoi 844 cube gas V-8.I believe is pretty much the same as the Roline.
    A huge engine is just that,a huge heavy slow reving engine.Using "high" gears to get road speed will difficult to use in traffic unless you have a very low first gear.
    GMC V-12's found a better use as agricultural water pumping powerplants.
    Big block Chevy misses this cutoff by a year for actual production engines..It's a no brainer to get 572 cubes from a BBC 454
  20. 73RR
    73RR
    Plenty of 426 wedge engines with 5/8 arms back in the old days...500"+.
  21. 3Kidsnotime
    3Kidsnotime
    from Utah
    No offense, but it would be a bit of a brainer cant be done.... you can use a late 80's truck 427 tall deck block they are siamese bore and 10.2 deck, but that wet 9.8 deck production 454 block wont work. The late production truck block is the only production block you can get 572, or buy a bowtie or one of the many other aftermarket blocks.
  22. stainlesssteelrat
    stainlesssteelrat
    from ms
  23. Truckedup
    Truckedup
    Yes,truck blocks ,I forgot that part :D But it's still easy cause the parts easily available,GM sells a crate 572,you might say that 's a production engine.But...too new.
  24. CutawayAl
    CutawayAl
    from MI
    120+ :eek: Going that fast in that car would feel like breaking the sound barrier.
  25. 3Kidsnotime
    3Kidsnotime
    from Utah
    Yea but stick a lump of coal in your ***, and the wife would be happy when your done... :eek:
  26. zman
    zman
    from Garner, NC
    easily stroked to over 454ci as Tommy Ivo and others did.
  27. CutawayAl
    CutawayAl
    from MI
    :d :d :d
  28. Piper106
    Piper106
    Any info on how big the bore and stroke was on that motor???
    Piper106
  29. Piper106
    Piper106
    A 426 RB bored 0.060" over and 5/8" stroker would be 4.312" bore x 4.375" stroke which gives 511 cubic inches.
    Piper106
  30. Piper106
    Piper106
    Anybody have any numbers on how big the 430 MEL could be bored and how much stroke it can hold???
    Piper106
