Bigs and Littles. What do you run?
Discussion in 'The Hokey Ass Message Board' started by Baron Von Mike, Jun 3, 2004.
  1. I checked on the HAMB tech board for this particular discussion, since it seems like something that would have been discussed before. I didn't see it there, so I'm asking here. Many of you have figured this out in the past I'm sure.
    I've got a 41 Ford Pickup, 15" rims, stock suspension. Over time it will get lowered, probably just by 2" front and rear. I would like to run bigs and littles, wide whites, for just the right stance and maybe a little better ratio at the rear.
    Looking for both Radial and Bias dimesions. Changing the rim diameter is an option. Pics of the resulting look would be cool. Spent a lot of time at Paso checking out everyones tires. Needless to say I got some weird looks. [​IMG]
    Thanks ahead of time.
    Mike
  2. Pigiron
    Pigiron
    Mike, I run 5.60x15 front, L78x15 on the rear of the 27T. 165R15 front, 235/75/15 on the Deuce. Did you read my messages?
    Mike
  3. Yep, I read your other messages. Thanks! I'm on the hunt for an SROD 77-81******* now.
    235 in the rear eh? With a tire that tall, do you experience any bounce, or are the sidewalls thick enough to prevent that?
  4. Slick mo fo
    Slick mo fo
    from San Diego
    A few things to think about-
    how much room do you have?
    Are you going to have to tub it for room?
    How low is it going to be?
    will they be tucked under the fenders?
    Do you have the power to turn them? Meaning, are they for looks, or do you need the traction?
  5. NealinCA
    NealinCA
    [ QUOTE ]
    I run 5.60x15 front, L78x15 on the rear of the 27T. Mike
    [/ QUOTE ]
    Can you get blackwall bias in those sizes? All I have seen are WWW's.
    Neal
  6. [ QUOTE ]
    [/ QUOTE ]
    235 75 R15 is a good series for the rear in radials
    if you don't wanna go that thin up front you have a lot of choices- i wouldn't go over 195 or 205....and stick with 70 series up front in the wider numbers.
    i'm running 205 70 15 up front and 225 75 15 on the rear of the F-1 now but i'm gonna switch the rears to 235 after i replace the springs.
  7. AnimalAin
    AnimalAin
    On my 41 pickup, I run 165R-15 on the front (15X5 rims), and P285/70R-15 on the back (15X8 rims). Those back tires are a little fat for a flatmotor, if I had one of those, I would probably go with the P235/75R-15. Other sizes to consider for the rear, if you haven't bought the wheels yet, are P245/75R16 tires on 16X8 wheels, or 235/75-16 on 16X7 rims. I run some 245s on my roadster, and they work well. They are not quite as wide as the 285/70-15, but are about the same height.
  8. jalopy43
    jalopy43
    205/75/r15 front, 235/75/15 rear Firestone721's medium1/1/2"whites
  9. jdubbya
    jdubbya
    I have 590-15's on 5" rims in front, and 820-15 on 6" rims in the rear of my 28 sedan. They are BFGoodrich Silvertown blackwalls. Here is a pic -Joe
  10. Pigiron
    Pigiron
    [ QUOTE ]
    [/ QUOTE ]
    The tires don't bounce on the Deuce. 22psi rears, 16psi fronts. The motor is a 302 Ford with a 4-71. The rearend is 9 3/8" Ford with 3.50 Traction-Loc. 3speed+ overdrive cast iron trans with 3.25 low and 30% overdrive. Gets 15 mpg and blows the tires off at will.
