Technical Blast cabinet vacuum for dust collection?
Discussion in 'The Hokey Ass Message Board' started by morepower, Oct 21, 2020.
  1. morepower
    morepower
    from northeast
    I need to add a dust collection system to my shop for the occasional woodworking projects. Will a SkatBlast vacuum do the job, or do I need special equipment? Thx!
  2. harpo1313
    harpo1313
    from wareham,ma
    I used a small shopvav vented to the outdoors.
    anthony myrick likes this.
  3. harpo1313
    harpo1313
    from wareham,ma
    My pal has a stove hood fan over his woodwork area and seems to work well vented outdoors. We are both the cheap and easy type.
  4. ekimneirbo
    ekimneirbo
    from Brooks Ky
    My son bought a tool to separate the dust out of his sandblaster. Its called a Dust Deputy and he says it works very well for him.
  5. MoparTobi
    MoparTobi
    from Macon, Ga
    I have a modified 5 gallon bucket between my cabinet and a small shop vac. Works great!
    BigDogSS likes this.
  6. BigDogSS
    BigDogSS
    from SoCal
    I also recommend the Dust Deputy. I bought the deluxe version with the buckets and everything to put it work quickly. It works great! https://www.oneida-air.com/dust-deputy
    Before the Dust Deputy, I had a modified a 5 gal bucket between the blast cabinet and the shop vac.
  7. Budget36
    Budget36
    I recall a HAMB’r making one with a 5 gallon bucket, some PVC pipe. As I recall he filled it about 1/2 way with water Pipe from the Blaster went into the water, exhaust from the bucket was above the water. The water stopped the dust. Drained as needed
  8. Paulz
    Paulz
    Another + for the Dust Deputy. It'll keep fines like sanding dust from clogging your filter in your shop vac, it pretty much catches everything before it gets to the vacuum.
  9. kabinenroller
    kabinenroller
    I have a Skat Blast cabinet connected to Dust Deputy, the exhaust from the D.D. Goes into a plastic five gallon bucket filled a third with water, the exhaust from the bucket is clean, no dust whatsoever. I did not want to penetrate an outside wall for exhaust.
