Technical Blasting material
Discussion in 'The Hokey Ass Message Board' started by johnfin, Jan 10, 2026.
  1. johnfin
    johnfin
    from Florida
    I went to get some more garnet 80 gritt blasting material from tractor supply and they no longer sell it. Its now coal slag. Any of you guys tried it. Cant use sand = cancer.
  2. 34Phil
    34Phil
    MSC has garnet
  3. Hollywood-East
    Hollywood-East
    It leaves a course finish...
    Highly recommend a quick da in any finish able to access..
  4. CDXXVII
    CDXXVII
    from Vermont
    I use coal slag (a.k.a. Black Beauty) on thick steel. Too aggressive for sheet metal in my opinion.
    Harbor Freight here carries a couple different blast medias. Maybe they have garnet.
  5. 41FordCouper
    41FordCouper
    from N ILL.
    Coal slag works on frames parts heavier rust ..Like said Too course though ..finer material =smoother finish..
  6. johnfin
    johnfin
    from Florida
    Any issues with plugging the nozzle, flow, or black lung?
  7. KenC
    KenC
    There are more than one coal slag grits. 12/40, 20/40 and 30/60. Finer works OK for me on sheet metal. IMO any blasted surface should get a quick p*** with a random orbit sander though. I usually use 120grit paper for that.
    I find the black beauty creates a lot of dust as it breaks up. Always have a good filter mask on. Lots of nasty stuff in coal slag.
  8. K13
    K13
    Shouldn't be blasting with anything without proper lung protection. You are kidding yourself if you think any of the materials are safe to breath.
  9. VOETOM
    VOETOM
    from MO
    John, go visit any water jet shop. They can sell you lots of garnet. i
    Damon777 and winduptoy like this.
  10. johnfin
    johnfin
    from Florida
  11. winduptoy
    winduptoy
    I prefer garnet...my water jet buddy turned me on to it....as said above, any water jet shop will have it and it is superior to anything else I have ever used
  12. rockable
    rockable
    Northern Tool carries both the coal slag and the amber blast (caused beer bottles), which i prefer. Works well on rust and paint removal. Also, I blast on about 70-75 psi. High pressure shatters your media and creates a lot more dust.. as well as increasing the chance of warpage.
  13. K13
    K13
    M C Empson and Tow Truck Tom like this.
  14. VOETOM
    VOETOM
    from MO
    You get all the stuff you blast off for sure so please be safe and wear the right equipment.
