Technical BLC 682, add turn signal inside ?
Discussion in 'The Hokey Ass Message Board' started by SDS, Jun 15, 2023.
  1. SDS
    SDS
    This has been covered in one way or another, but the thread are old and some manufacturers don't do it any longer, but...
    Does anyone know of a kit or a way to convert my original BLC 682's, which have a sealed beam headlight bulb, to something which has turn signal internal to the headlight bulb?
    Thanks~
  2. Mr48chev
  3. Happydaze
    Happydaze
    I've seen 7" sealed beams lights with a clear section on the reflector so that an indicator or parking light can shine through. Plan b could be halogen conversions. Before you puke, do bear in mind there are pretty authentic domed lens versions. These can come with a separate light.
    Chris
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. Mr48chev
    Personally I'd just run a pair of small amber motor cycle turn signals that didn't draw much attention to themselves except when they flashed. Similar to this one from Drag Specialties. eBay item number:304163398360
    Tman likes this.
  6. Mr48chev
  7. Those are Euro-spec lights, but that lamp is really designed to be used as a parking light when the headlights are off. If used as a turn, it's not very visible when the headlight is on if you use a clear lamp. You can install an amber lamp, but then the light looks weird. Another issue is that's another entry point for moisture which will eat the silvering off the reflector.
    Ned Ludd likes this.
  8. treb11
    treb11
    IDK the current legality, but headlights have been wired to flash and act as a turn signal.
    Hell the new hot thing with OT late models is the light goes off and the fancy LED surround flashes.
    de-fenders and Tman like this.
  9. alchemy
    alchemy
    I thought roadster guys used their arm for turn signals.
    da34guy, RICH B, de-fenders and 4 others like this.
  10. Joe Blow
    Joe Blow
    If you can't find a light to your liking.....you could always convert your J's to C's.
    29.00
    22.00
  11. SDS
    SDS
    NH mandates you have a turn signal - I'm going to wire it for these, and try to get tags without.
  12. Mr48chev
    These damned fools around here wouldn't recognize a hand signal from a car if you slapped them in the face with it. Once in a while you see guys on bikes use hand signals but I haven't seen hand signals from cars for years.
  13. SDS
    SDS
  14. Happydaze
    Happydaze
    SDS likes this.
  15. chickenridgerods
    chickenridgerods
    from DSM, IA
    Your 1932 roadster was manufactured prior to 1952. You aren't required to have directional signals.
    https://www.gencourt.state.nh.us/rsa/html/**I/266/266-42.htm
    Code:
    CHAPTER 266
    EQUIPMENT OF VEHICLES
    Lights, Signals, Flashers, Reflectors and Flags
    Section 266:42
        266:42 Directional Signals. – It shall be unlawful to drive on any way in this state any motor vehicle registered in this state which is manufactured or ***embled after January 1, 1952, unless such vehicle is equipped with directional signals approved by the director. The provisions of this section shall not apply to motorcycles manufactured prior to January 1, 1973.
    Source. 1951, 20:10. RSA 263:37. 1981, 146:1. 1994, 88:1, eff. July 5, 1994.
    Tman likes this.
  16. SDS
    SDS
    Well...it's a reproduction ch***is and body with no VIN #...AND I have open front wheels.
    I have to get a NH "street rod registration"/***le/plates.
    To be able to get this, a cop or a qualified salvage yard guy has to confirm that the vehicle is safe and in working order...this typically leads to turns signals being necessary. :(
    Thanks though, I'll be sure to bring up RSA 266:42 when the inspection is occurring - I'm sure they don't do many or these ***les and they are not 100% on the rules. maybe I can get 266:42 to "apply".
    Johnny Gee likes this.
  17. chickenridgerods
    chickenridgerods
    from DSM, IA
    That’s unfortunate.
