BLC headlight tag rivets?
Discussion in 'The Hokey Ass Message Board' started by Montana32, Jul 18, 2012.
  1. Montana32
    Montana32
    I'm looking for proper rivets to attach the tags to BLC 682J headlights. My tags are good, but I'd like to take them off to paint the lights rather than masking them. If you know of a source, I'd like to know it. Thanks
    Steve
  2. Fred A
    Fred A
    from Encino, CA
    I have cut off the inside of the rivet to remove the tag then after blasting the bucket, cleaned off the tag and rounded off the remaining rivet with a brush and dremel tool. After painting, this was put back on, held by trim cement. Seldom is the best bucket and best tag on the same light. Amaziong how common these lights are and how good they look. Good Luck: Fred A
  3. damagedduck
    damagedduck
    from Greeley Co
    i thought someone here was selling em?
  4. larryj
    larryj
    from Madison AL
    OTB Gear has them. http://www.otbgear.com
    I didn't see them on the website but they told me on the phone they had them. Give them a call.
  5. Clark
    Clark
    I use split rivetts. You can get them at a good hardware store.
    Clark
  6. sskustoms
    sskustoms
    193257 on here sells tags and rivets send him a pm for info
  7. striper
    striper
    I think Macs has 'em too
  8. A Boner
    A Boner
    You can use small, like 4/40 brass machine screws (use the size screw that fits in the tag hole best). Just spin them in a lathe to the correct head diameter, and to turn off the slot at the end. Use a small amount of lock- tite on the nuts. When you grind off the old rivet, do it on the inside of the headlight bucket so you don't F-up the tag.
  9. BIG-JIM
    BIG-JIM
    from CT
    I have them if you need any. Just a couple of bucks to your door.
  10. ALEISTER
    ALEISTER
  11. Jeff Norwell
    Jeff Norwell
    MODERATOR
    193257 is a great fella.....superior product.I fully endorse his work and product.
