bleeding clutch slave cylinder?
Discussion in 'The Hokey Ass Message Board' started by JDiGio1960, Apr 24, 2012.
  1. JDiGio1960
    JDiGio1960
    from Ventura,CA
    so my clutch clave cylinder went out on me, and i ordered a new one... however when it comes to bleeding, i have no idea what i am doing.. could anyone help me? its on a1960 f100 with an inline 6 and a three on the tree. thank you!
  2. bobscogin
    bobscogin
    If the master cylinder is higher than the slave and the bleeder fitting is positioned correctly, you can gravity bleed it. Just open the bleeder and the fluid will move downward and fill the system. When you see fluid with no air bubbles coming out, you're done.
    Bob
  3. skwurl
    skwurl
    I use a vacula. Then pump the clutch pedal a bunch of times until you get a pedal.
