Hot Rods Blending Acrylic Urethane...
Discussion in 'The Hokey Ass Message Board' started by Fortunateson, May 29, 2024.
  1. Fortunateson
    Fortunateson
    Last fall I accidentally buffed through a small area on an Acrylic Urethane paint job. After the almost resolved medical issue(s) I’m back to final re***embly.
    Now I know I could repaint the whole panel but I thought I’d like to try a blending process. The paint is SS.
    Any tips/tricks?
    I’ve already reached out to Anthony....
    anthony myrick likes this.
  2. JimSibley
    JimSibley
    What color is it? Where on the car is it? A pic would be helpful.
  3. oldiron 440
    oldiron 440
    You can prep panel blend the color and spray urethane clear coat on the panel. It’s very difficult to spray an invisible blend with single stage, if you get the blend correct the shine probably won’t be. And if you think your going to buff the blend good luck, you would have better results blending then blending with clear coat because you could sand and buff the clear without hurting the bend.
  4. Mid 90s was the last I’ve seen SS paint blended. That was done with over reduced clear
  5. onetrickpony
    onetrickpony
    from Texas
    There are some products designed to help melt the edge when blending. My gut feeling says to repaint the panel on ss.
    For some tips on blending, look up Paint Society on YouTube. It's mostly bc/cc but you may find some usable tips. The worst case, you screw it up and end up repainting the panel, anyway.
  6. Post a pic of the spot.
  7. Bandit Billy
    Bandit Billy
    I have a theory that pinstripes/flames/scallops where first used to cover paint defects like buff throughs, rock chips, runs, etc. Since it wouldn't match or blend, just pint it a different color and make it look intentional. Like I said, just a theory. :cool:
  8. onetrickpony
    onetrickpony
    from Texas
    Finally, a use for those fake bullet holes!
    Bandit Billy likes this.
  9. Fortunateson
    Fortunateson
    Thanks for the replies. One reason for advice was I thought it might be cool to learn another process. The other reason was to fix the goof up.
    My choices now may be repaint the whole panel or get some of those fake bullet holes!
    The colour is Imperial Sapphire Blue. A TR6 colour and almost navy blue. But it compares perfectly with original under the garnish mouldings of my ‘32 Ford Washington Blue!
    I’ll try to get a couple of pics...
    SS327 and anthony myrick like this.
  10. I have used the 2 gun method before. You may or may not be successful. :)
