Yep heard a snap and grinding noise from the transmission, wouldn't do anything and saw a big puddle of ****** fluid. So i coasted it down the hill into a safe spot. Time for the 302 to go into it. I'm currently sitting on the side of the road waiting for a damn tow truck
That ****s! If I wasn't scared of green wooded areas I leave the concrete jungle of Seattle and help haul your *** home. Best of luck & hope things don't cost too much.
Y-block/Fordomatic or FE/cruise-o-matic? (at least I think those were the two automatic options?) Malcolm
I hear ya man! My girlfriend's '54 Customline has a 223 and a 2 speed auto and I'm just waiting for the day that it looks at me wrong and its time for a 302 and an AOD in that car! Hope you got it home safe!
Well after a interesting day I pulled the ****** pan off and found a ton of friction material at the bottom but no chucks. We now believe the torque convertor took a **** along with the governor. But the 223 and ****** are now out and the car is awaiting the 302.
The engine I'm putting in it is just a stock 302 out of my 77 mustang. I am building a 302 that might be a roller that will eventually go in but that's down the road.
You darn kids and your cars ! I say it needs a big C.I. FE engine and FMX trans ! Yikes ! single stage master cylinder ! time for change on that kiddo !
A set of motor mounts for a 289 63 galaxie and it sits in the stock 6 cyl frame mounts. No cutting at all (we done this swap in my brothers fullsize) good looking car, hope to hear its on the road soon.
Easier than u think. Will need a front sump oil pan from mid 70s back fullsize car. If u use an 85? And earlier aod, the overdrive is cable operated and u can use the stock column shifter too. My old 63 got 22 mpg with that set up snd im doin it again to my 58 this winter. 82 up ltd/crown vic radiator fits easy enuf to with easy to make top brackets.
Actually those early AODs are rod operated instead of cable. TCI makes a constant pressure valve body that ends the gnats *** adjusment or burn up the ****** problem that AODs have.
