Block hugger headers with angle plugs or AC, are there any?
Discussion in 'The Hokey Ass Message Board' started by Dyna, Apr 19, 2011.
  1. Dyna
    Dyna
    from London
    Been looking at block hugging headers but all I find is once not working with angled plugs. It also looks like they never will work with stock 1966 Chevelle SBC air compressor brackets.
    My question is if there is any short block hugging header than is going more down before crossing over to the collector. Sorry don't really know how to describe it.. but I hope you understand.
    Cheers Dyna
  2. FoxSpeed
    FoxSpeed
    from NorCal
    Give sanderson headers a call or email them in South San Francisco. They will most likely lead you to a solution. Perhaps even build you a set.
  3. FoxSpeed
    FoxSpeed
    from NorCal
  4. TRUCK_RAT
    TRUCK_RAT
    from tulsa
  5. Dyna
    Dyna
    from London
    Thanks all of you.. The latter on from Truck Rat will probably fit, bit small although --- 1 5/8 and 3 would probably be the best for a 421.. Sanderson is very interesting.. will definitly give them a buzz..
    Cheers dyna
  6. had a set of Sanderson's on my coupe with angle plugs. Don't remember the p/n.
  7. aaggie
    aaggie
    Another vote for Sandersen, they make up to 1 7/8" tubes. I went with 1 5/8" for my '40 Chevy, interesting that they don't use gaskets. They reccommend a bead of high temp black silicon to cure overnight them torque to spec.
  8. So do you actually have a 66 Chevelle? If so why not use these from Patriot H8021-1. They fit with AC and angle plug heads
    They also make at least 4 Block Huggers that fit with angle plug heads; H8019, H8037, H8052 and H8065
