Blower drive question
Discussion in 'The Hokey Ass Message Board' started by ARNIE, Oct 9, 2011.
  1. ARNIE
    ARNIE
    Sat. I ran the "High Times" Crosley Dragster. Best ET yet! (18.10) Thanx to a new Stromberg 97 from the Hot Rod Co.! Shutting down early due to oil leak. (I thought it was gas!) My question is :what is my blower drive over drive%. I have a 5" crank pulkley & a 4 1/4" blower pulley. Does anyone have the formula to figure this out? Thanx~!! Arnie
  2. Candy-Man
    Candy-Man
    Approx. 17.5% if my math is correct, however; it usually goes by tooth count on the pulleys.
  3. squirrel
    5 divide by 4.25 = 1.176 so it's about 18" overdriven. But that's probably not exact, because you probably measured the outside diameter instead of the pitch diameter. It should be pretty close though.
  4. ARNIE
    ARNIE
    Thanx! I thought there would be an easy way!
