Technical Blower I.D.
Discussion in 'The Hokey Ass Message Board' started by flathead_10, Nov 15, 2016.
  1. flathead_10
    flathead_10
    from Kansas
  2. DDDenny
    Not a clue, never seen one before.
    What does that plate on the bearing case say?
  3. Fordors
    Fordors
    I never saw one either, but keep in mind all blowers were not necessarily used on engines, some were just industrial applications.
    stillrunners likes this.
  4. flathead_10
    flathead_10
    from Kansas
  5. squirrel
    the number stamps remind me of old Japanese stuff....huh....
  6. stillrunners
    stillrunners
    from dallas
    What was that small blower they put on those little diesel generators - a 241 or what ? Dam if I wasn't at an auction years back.....there was a little generator with a little blower...couldn't stay....and stuff was going cheap.....my timings always off......
  7. 19Eddy30
    19Eddy30
    from VA
    Cool !!! I would LOVE to have ,,
    I would run it on my Flatty.
    Never seen one like that ,
  8. How long has Eaton been in business? Has a similar look with the flat base flange.
  9. mgtstumpy
    mgtstumpy
    How many blades on rotors?
    Industrial blower
    loudbang and kiwijeff like this.
  10. flathead_10
    flathead_10
    from Kansas
  11. Never seen one either. Neat whatever it is.
  12. alchemy
    alchemy
    Old br*** plate like that seems at least as old as the 40's. Probably not Japanese with English characters on the plate.
    flathead_10 likes this.
  13. mad mikey
    mad mikey
    Very cool blower, wish I knew what it is and what it was used for. I am guessing a industrial application .
  14. Could the br*** tag be a rebuild ID number?
  15. RainierHooker
    RainierHooker
    from Tacoma, WA
    looks like a Detroit 53 series blower with some odd end plates. Several different sizes and variants were made. Most likely out of a marine or industrial application...
    loudbang and stillrunners like this.
  16. squirrel
    In general, it looks like a 53 series blower. But none of the details match. At all.
    weps and Hotrodmyk like this.
  17. 270ci
    270ci
    Interesting piece. Is it held together with metric bolts or American Standard?
  18. flathead_10
    flathead_10
    from Kansas
    It's standard. All of the bearings are "made in USA" and all of the casting numbers are in English
    Sent from my HTC6525LVW using The H.A.M.B. mobile app
  19. DDDenny
    This is a handsome little blower and I'm quite surprised that more people haven't replied with information.
    I like the way the bolting lugs continue up the housing. Has a considerably beefier appearance than most of the common blowers. Surprised this design hasn't been incorporated into modern racing superchargers.
    Curious what the overall dimensions are compared to the GMC 471 and 671 cases, as well as the bolt spacings.
  20. Fordors
    Fordors
    The -53 series blower mounts with bolts through the end plates but the one pictured by the OP has mounting lugs on the case, I still believe it's industrial. There was also a short lived -51 series engine and those blowers mounted like the -53's.
  21. yellow dog
    yellow dog
    from san diego
    Intriguing.....I once re-purposed a military surplus roots for a small displacement engine.
    Anyway a couple of clues as to its origin will help in re-purposing. I would say it was an industrial
    origin except that it has square mounting flanges. The manufactures of industrial units that I'm familiar with use standard round pipe flanges and this would seem to indicate it was for a specific application. The drive end would appear to only have a single bearing and might have been close coupled as opposed to tangential loading. As far as applying to an engine, Steel vs aluminum rotors would also be a clue . I would rather have aluminum rotors rather than steel if pumping fuel/air at rpm. My surplus Sutorbilt had a similar reservoir in the back and zirks on the front and probably designed for direct coupling and low rpm. The case and rotor volume will be eventually helpful for rpm vs cfm. I really like the mounting flanges and looks like it could be a fun project.
  22. flathead_10
    flathead_10
    from Kansas
    The drive is a bolt on double v belt pulley "that I didn't get with it, with a self-contained ider. The rotors are steel.
  23. Bruce Lancaster
    Bruce Lancaster
    A possible other source...in the immediate postwar surplus ads in the back of magazines like Popular Mechanics, there are roots blowers whose job had to do with pressurized cabins in aircraft. The pictures I remember were small and crude, not really helpful. Pressurized planes were just beginning to be important in WWII...I think the B29 used pressure.
  24. DDDenny
    Seeing you are in SD, I'm reminded of a story told by my friends older brother about 1967.
    He was in the Navy and claimed he saw a pallet of new GMC 671 blowers being dumped into San Diego Bay.
    I will never forget hearing this story.
  25. yellow dog
    yellow dog
    from san diego
    "Seeing you are in SD, I'm reminded of a story told by my friends older brother about 1967.
    He was in the Navy and claimed he saw a pallet of new GMC 671 blowers being dumped into San Diego Bay."
    sounds very feasible...I made 3 Westpac cruises in this era...where we were told that unless we
    spent our budget that we'd be cut for going forward. People were suppose to dump their tool
    boxes, etc. I never actually saw anything being tossed and the tools I collected over time were special
    to me. I actually worked 34 yrs at a chemical plant on the bay next door to a Navy repair facility and
    32nd street, but that wasn't until 1972
  26. flathead_10
    flathead_10
    from Kansas
  27. DDDenny
    Cute little peanut.
    I bet when set up right that would work great on a small cid engine.
  28. flathead_10
    flathead_10
    from Kansas
    Hopefully it will be good for few pounds of boost on a 276 Flathead.
    cadillacoffin likes this.
  29. stillrunners
    stillrunners
    from dallas
    ok...going thru my industrial catalogs........maybe not it.....GMC had a little 4cyl with a blower....series 51 ?
  30. flathead_10
    flathead_10
    from Kansas
    The 51 one series blowers are similar but are not a match. The 51's mount via four bolts in the bearing plates.
