Technical Blower pulleys size
Discussion in 'The Hokey Ass Message Board' started by Oldfart59, Dec 18, 2020.
  1. Oldfart59
    Oldfart59
    Looking for what size of 8mm pulleys to run
    6v92 blower trying to get around 5 to 8 pounds of boost
  2. Jmountainjr
    Jmountainjr
    What application? Most street stuff runs between 10% under driver to 10% over driven relative to crank speed. So you may have to pick a starting point and go from there. Are you sure that's a 6V92 blower?
  3. Mike VV
    Mike VV
    from SoCal
    Jr.
    You're hooked to the internet...use it...
    One bit of good info I found in about 10 seconds, tooth count, overdrive...and..."approximate" pressure. All right there on one page.
    In another few seconds, I'd bet there are more if you don't like Dyers info.
    But, alas, it's a task that you should be doing..!
    http://dyersblowers.com/pulley_boost_charts.html
    Mike
    mad mikey likes this.
  4. Hollywood-East
    Hollywood-East
    At a guess I'd say your 15-20 under Driven given pulley size
  5. Fordors
    Fordors
    The blower in the photo must not be yours, it’s a 4-71. Also, what engine are you building? I think that’s a 250 Chevy is that right?
  6. Oldfart59
    Oldfart59
    My is a 292 Chevy bored out to a 301
    My blower is a 6v92 blower
    I just don't know what my blower puts out so I would like to be around 5 to 8 pounds of boost
  7. mgtstumpy
    mgtstumpy
    Charts may ***ist with pulley sizing to determine over or under drive and boost? Think they're 1/2" pitch
  8. Dean Lowe
    Dean Lowe
    Who set up the blower? I would think they could tell you what pulleys to use to get what you want.
    mgtstumpy and mad mikey like this.
  9. Oldfart59
    Oldfart59
    I redid the blower so I don't want to get way to much or no enough
    One guy told me 50 and 55
  10. 270ci
    270ci
    Your 6V92 has the same case ID and rotors as a 6V71 and displaces 338 c.i. per revolution. Your engine uses 301 c.i. in two revolutions.
    Using Dyer's reference charts, you'll want to be 15% underdriven to stay around 8 pounds max boost on your 300 inch motor. Using a 50 on the bottom and a 55 top will only be 9% under. You'll need a 60 top to get closer to 15% under with a 50 tooth bottom, or another combo altogether.
    Post some pics of your set up. Blown sixes are still rare.
    VANDENPLAS likes this.
  11. Oldfart59
    Oldfart59
    I will when I get it all together I post pictures when I get it together
  12. jimmy six
    jimmy six
    I thought bower guys were like quick change guys... at least 10-15 sets. Hell it’s only money but 9-10 pulleys and play around a lot.
