Blown 241 Hemi
Discussion in 'The Hokey Ass Message Board' started by 73RR, Nov 21, 2011.
  1. dustdevil
    dustdevil
    from illinois
    I'm jealous. That's a bad*** motor!! Would be sweet in a king ch***is setup!!
  2. jtille
    jtille
    very very NICE!!! over 3x the hp than stock!!
  3. Blown Red Ram
    Blown Red Ram
    from Kelso,Wa.
    The intake started out as an Offenhaeuser tri power. Don Hampton converted it. I furnished a 4-71 blower core that he rebuilt. Don also supplied all of the drive parts , hardware and gaskets.
    Tim
  4. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Don is a good man.
  5. brigrat
    brigrat
    from Wa.St.
    Jeff, does this mean you have your huffer?
  6. fryguy
    fryguy
    Very cool Hemi
  7. strombergs97
    strombergs97
    All I can say, it's ******ic. I have a 241 in my 1935 Ford Sedan..Love it..
    Duane.
  8. jimi'shemi291
    jimi'shemi291
    Damn SHOW-OFF!!!:mad:
    (But, MORE Yuuuuuuuummmm!!! :D:D:D)
  9. strombergs97
    strombergs97
    OH, didn't Don Garlits run a 241, his first hemi. He took it out of his friends 40 coupe.
    Duane.
  10. jimi'shemi291
    jimi'shemi291
    And I do think Lee Petty won the '54 Grand
    National Cup with a Royal or Coronet 241 Hemi,
    both rated at 150-horse at 4,400.
  11. 38Chevy454
    38Chevy454
    Very cool on building the little HEMI. I suspect there is even more available with some tuning and you got the 427 hp with only 10 lbs boost.
  12. falcongeorge
    falcongeorge
    from BC
    My thoughts EXACTLY! Lets hear it sing!
  13. George
    George
    In the Tex Smith book he says it was a 331 out of a '54 NYer. He said he hurt the crank & "borrowed" a '51 331 from a buddy's car, probably what you were thinking of.
  14. Blown Red Ram
    Blown Red Ram
    from Kelso,Wa.
    Don is great guy to deal with.Very patient with my questions on the phone.He even told me when I sent the blower to him to send my Hilborn injector too. He'd drop it off at their place for a rebuild "no problem".
    I don't know how much power is left in this combination without a bottom end girdle. A roller cam and rockers would make me breathe easier when it's making that power!
    I've gotta figure out how to post video first. It'll be down the road a bit.There's more blower sound then exhaust noise. The neighbors said it was too damn loud!
    Tim
  15. brigrat
    brigrat
    from Wa.St.
    Here's '41z ugly, older sister a '39 Willys P/U that is at my shop, I could ask the owner if it's available and if so put the 2 of you together if there is any interest? Can't promise a thing but it is close to you!
  16. stillrunners
    stillrunners
    from dallas
    and to think I was being sneaky getting a Dodge 270 and 241 truck poly's to go with my LRR's and D500 hemi's....got to make something work :eek:
  17. 8thdaycr8
    8thdaycr8
    After seeing that picture now I know I really need to finish my motor. I have a performance cam and lifters, just need carbs, pulleys and machine work finished.
  18. 73RR
    73RR
    Start a build thread and keep us posted! Looks like you have a good start.
  19. Locomotive Breath
    Locomotive Breath
    from Texas
    That's a stout little engine. I just wonder how much the crankshaft will take, those little journals make me nervous.
  20. lolife
    lolife
    With that kind of horsepower, they are probably going to use it in an application where longevity is not the goal.
  21. t5stang91
    t5stang91
    has anyone put a turbo on a 241? just wondering, i have a 241 for my model a truck and have been thinking of 1 or 2 turbos for it would look good. can't seem to find any of these blower manifolds anywheres.
  22. 73RR
    73RR
    Buy a new Offenhauser manifold and modify the top as needed for your application...
  23. George
    George
    I think I'd get a high deck Dodge, or a DeSoto/Chr instead on trying that on a low deck Dodge.
  24. t5stang91
    t5stang91
    just a regular 4 barrel intake? or dual quad intake?
  25. t5stang91
    t5stang91
    heard the little hemis are nice because they are lighter and they also rev faster. is this true ?
  26. Sinnen
    Sinnen
    I just picked up a 241 punched to a 270. don't know if i got a good deal or not but its going in my 30 model a coupe project. It has the original crank, new pistons, aftermarket springs and valves,.400" cam, 8to1 compression, weidon intake and 4 97's and a malory dual point dist. It is suppose to be fresh rebuid. Does this info seem like it will work good? I don't know alot about these motors been on here trying to learn. Engine is my avatar. thanks for any info!
  27. George
    George
    The "problem" area is the cranks, adding a harmonic balancer would be the cure on a natural asperated build, but I don't think I'd put a blower/turbo on one. Personally a damper/balancer & 9 or so to 1 pistons(verified, the OEM C/R is listed @ 7.1:1 but @ least one was measured @ an actuall 6.19:eek:) & the usuall build stuff should be a perfectly fine engine.
  28. 73RR
    73RR
    Any aluminum manifold can be made to work. Currently, Offy offers a 1x4 and a 2x2....I would use the 2x2. Contact dmarv for Offenhauser stuff then talk with TRWaters for the machine work.
    If you are happy with the cash/engine exchange then you got a good deal...
    Have you verified the overbore by comparing the ID code to the finished bore? I am unaware of any 8:1 pistons on the market, where did this number come from?
    Does it look fresh?
    What is a weidon intake? Pics?
  29. RichFox
    RichFox
    A 241 punched to 259-260, depending on which way you were facing at birth, is pretty common. 270 seems a little big.
  30. 73RR
    73RR
    0.1875" is more than just 'a little big'...:eek:
