Blown 241 Hemi
Discussion in 'The Hokey Ass Message Board' started by 73RR, Nov 21, 2011.
  1. jimi'shemi291
    jimi'shemi291
    Jeez, I'd say! The walls to the water jackets would start to be see-through! Even if there's enough meat there, I think that would be pushing the Baby beyond reasonable limits.
    JMO, but the HAMB Hemi gurus willingly participated in a hypothetical exercise with me a couple of years back when I first joined. I asked how far the 330 hi-deck DeS could be punched out. The max (with reservations, I might point out) was .125, though somewhat less was recommended. My dad never exceeded manufacturer's standard oversize. A rodding friend of mine punched a Ponch way out and sleeved it; when he tore it down for a rebuild, he said he still found signs of overheating, though no sign of fatigure into the water jackets. He still felt the experiment was worthwhile but said THAT was his ONE time doing that. (Notably, he pushed his engines to the max when backroad racing, BTW.)
  2. 32 Spitfire
    32 Spitfire
    Here is "Red Ram Corner"!! I've been collecting a few complete engines the past several years and extra heads.
    Two complete Dodge Red Rams and a poly 270 block getting ready to be built by my good friend Doug for my next 32 Ford which will be a 3-window. Doug plans on putting spare heads from a 241 on the 270 poly block. We will be using the three carb set up however I better not let him see this blower stuff!!
    32 Spitfire
    http://www.jalopyjournal.com/forum/showthread.php?t=643065&highlight=32+spitfire
  3. George
    George
    I blew right past that w/o noticing! He may have an expensive paperweight there!
  4. Blown Red Ram
    Blown Red Ram
    from Kelso,Wa.
    My engine is only .040 over stock bore size.
    Going to spend my saturday out in the shop making a roll around cart to put it on . It needs to be stored in tha ba*****t family room for the winter. Then I can put all the Hilborn stuff on while I'm watching Speed or an old "And They Walked Away " video.
    Tim
  5. Sinnen
    Sinnen
    Thats what the guy said, hope its not a paper wieght. I have the guy # that built trying to get ahold of him. Here are the #s on the block D44 I23339. And I ment Weiand intake sorry.
  6. Mopar Jack
    Mopar Jack
    Hemi!!!.....Says it all....
  7. 73RR
    73RR
    D44 is a 241 so now the question is: what is the existing bore diameter?
  8. George
    George
    Yeah, if it's that big a bore he might want to pull the pistons & see if it can be sleeved back to 259 or 241.
  9. Zoo York
    Zoo York
    from Zoo York
    I ordered a manifold from exter. I should have it this week. I will have a writeup all about modding the manifold to fit the blower on. I'm in the mock-up stages now. Gerry[​IMG]
  10. Sinnen
    Sinnen
    I got a hold of the guy that built it, he said they sleeved one cyl. and it is not a punched to a 270. I am going to meet with the guy and get more info. He said it is balenced, new custom push rods, new eddy pistons, I am going to get a list of everything else. Sounds like he knew what he was talking about.
  11. 73RR
    73RR
    New what??
  12. RichFox
    RichFox
    If it was mine I think I would open it up and see for myself what's in there
  13. bob t!
    bob t!
    Isn't Egge a cast piston? If so is that a good idea in a supercharged engine?
  14. Mopar Jack
    Mopar Jack
  15. t5stang91
    t5stang91
    would think you would want forged, or in worst case a hyper if they even make them. i am still trying to learn on these old engines so bare with me.
  16. monc440
    monc440
    Gerry
    Keep us posted on this one. I'm going to need to make or modify a blower intake soon. Considering the cost of a 4brl or 2 2's intake I was considering making mine from scratch. I have access to a machine shop and tig welder.
  17. I kick myself every day for selling the 241 I had..........it even came with a manual trans bellhousing..... It was a running engine at that...
    Yup those baby Pachyderms will surprise you.....
  18. 73RR
    73RR
    ...max of 3-4psi... and then only maybe.
    I have remnants (chunks) of a 392 that had a blower on cast pistons...
    It is only an additional $300-$400 for forgings but yet the damage can exceed thousands....
  19. Zoo York
    Zoo York
    from Zoo York
    Here is the offy 4 barrel manifold I used. I opened it up and machined it flat so I could weld the plate on. I am almost finished with the adapter plate. Rite after that I will weld it to the manifold. I'll do a walk through once I'm done with everything.. Gerry[​IMG]
  20. brigrat
    brigrat
    from Wa.St.
    Not questioning your work but wondering if you had that intake bolted to a block with mounted heads before all the welding?
  21. Zoo York
    Zoo York
    from Zoo York
    nothing is final yet. Just flattened out the intake. I been using the round about measurements off this manifold. And also with test fitting..
  22. Blown Red Ram
    Blown Red Ram
    from Kelso,Wa.
    Brigrat,
    I can resist anything but temptation! I'd like to look if it's available.
    Thanks,
    Tim
  23. That is awesome how you modified that manifold... thinking outside the box...
  24. dirt t
    dirt t
  25. TR Waters
    TR Waters
    from Vermont
    Flow numbers for?
  26. Bonneville Avanti Dan
    How about dropping it in this:
    and going to Bonneville in August? The record for the "E" cl*** is 212.883. The car will do it if the engine is up to it.
    This year will mark 50 years of Land Speed racing for this car. Hope to get it out there so people can see and enjoy a real piece of Bonneville history.
    If someone has blown 306 cid to 373 cid hemi we could chase after the record the car already holds at 239.208 mph. That was on fuel. Gas record is 224 mph.
    Dan
  27. George
    George
    A friend has been thinking of dropping a hemi in his Avanti!
  28. mart3406
    mart3406
    from Canada
    Wow! That little Dodge Hemi would
    be sweet, sweet, sweet, in an Anglia!
    It'd probably fit pretty well too!
    Mart3406
  29. 73RR
    73RR
    I just received a updated pic of the littlest Dodge with a cute little 2-port injector...
  30. BashingTin
    BashingTin
    That thing is Bad-*** looking!
    What plug wires are those?
