blown 303 Olds gets magneto video(s)
Discussion in 'The Hokey Ass Message Board' started by Paul, Nov 1, 2008.
  1. Paul
    Paul
    Editor
    got this Vertex magneto from Touchdowntodd this morning, stuck it in and fired it up.
    first clip I let the R's drop too quick and killed it, gotta do something about that, maybe lose the aluminum clutch and pressure plate, or at least let off a bit slower, like in the second clip.
    thanks touchdowntodd
  2. GOATROPER02
    GOATROPER02
    from OHIO
    Hey Paul,
    Those style mags even in premo condition have a weak spark at idle
    To combat this you need to run about a .012-.014 plug gap compaired to what your used to
    They will fire a.060 gap at RPM but you have to get there first:)
    Tony
    Ross Racing Engines
    Niles,Ohio
    330-544-4466
  3. stude_trucks
    stude_trucks
    Looks and sounds real nice! Love the look of the vintage 4-71 as well. Can't wait to get my 392 hemi running with the Cragar 4-71 on it. Nice inspiration.
    On topic, what are the advantages of running a magneto verses a distributor? I know you don't need a generator and/or battery for them for a racing motor. But that only helps if you don't have lights, heater motor, wipers, etc. that you will need a battery/generator for anyway. Do they have better performance too or is it mostly about eliminating the battery and generator from a race application?
  4. Paul
    Paul
    Editor
    thanks for the tip,
    I did reduce the gap to .018 and it does seem ok but,
    I'll try a little less and see if there is any improvement..
    not that I've had any starting issues yet..
    damn rain though, I want to take it out!
  5. GOATROPER02
    GOATROPER02
    from OHIO
    You also may want to try a couple extra degrees initial timing as "your " olds my not like that exact advance curve but a couple degrees may help it
    Of course we all can tune behind the screen
    Tony
    Ross Racing Engines
    Niles,Ohio
    330-544-4466
  6. Paul
    Paul
    Editor
    biggest advantage, it's caveman technology that actually works
    a nice hot spark that gets hotter as the R's go up..
    properly set up and dialed in electronic will do better
    but where is the fun in that?
  7. HemiRambler
    HemiRambler
    I run .020 - .022" gap on my Vertex (locked) running alcohol with no problems firing or starting.
    You may want to have yours checked out. While at it you can also have the "good" magnets put in there for even more zing.
  8. F&J
    F&J
    What is the cam? ..geez it sounded snappy in the first clip
    make more rocket videos:cool: or anything with an old motor..
  9. touchdowntodd
    touchdowntodd
    wow man, KICK ASS! glad it all worked for ya, told ya it was ready to go!!! now u just need a big heavy ass spring on the throttle return to slow it down a lil
    hot damn i LOVE your car!
  10. Paul
    Paul
    Editor
    put the tach and timing light on it again,
    if I'm reading this right,
    at the crank it looks like;
    22 degrees total mechanical advance
    starting at aproximately 1500 rpm
    and all in around 1800...
    does that sound like it starts a bit late?
    right now I have it set at 12 degrees initial,
    it starts easy and idles nice..
    no aparent issues but
    'won't know how it runs on the street until the rain lets up.
  11. DON_WOW
    DON_WOW
    Howdy Paul,
    Thinking if you can get the advance to start coming in around 600 to 800 rpm and be all in at
    1800 to 2000 ,,you would be more pleased with the feel and response thru the rpm range.
    You have a light switch instead of a curve as it sets----- initial at 12 is good ,might be able to increase it a couple degree's and get total to 36---if gas is not a issue.
  12. touchdowntodd
    touchdowntodd
    damn i hope the rain lets up i wanna hear how ya like it on the street
  13. CGkidd
    CGkidd
    Damn paul. I will be home in a couple of weeks. I really need to stop by and see that. I am hoping to fire my engine this inport.
  14. Paul
    Paul
    Editor
    I put the timing light and tach on it again yesterday,
    just using basic tune-up type tools,
    a bit hard to watch both at the same time but I did it several times and it looks more like it starts at about 850 at it's all in around 2000
    I played with the initial timing and it seems to like it at 12 degrees best.
    rain did let up yesterday so as soon as I got home I was out driving it around, it works every bit as good as I could have hoped.
    nice and strong and responsive
    now to go into the carburetor, this one is just one I had laying around, I had it all dialed in to work on a dual quad tunnel on a fairly healthy 454 so it's already a bit "fatter" than out of the box.
    close but it could probably use some fine tuning
    been wanting to lose the Edelbrock all together and run some two barrels
    maybe a couple large 2GCs..
  15. Brock49Ford
    Brock49Ford
    Cool! Must have missed this the first time around. Sounds pretty damn good. It was impressive when I heard it the other week, that Mag sure makes a difference. OK now I am even more motivated...but I am a lot poorer. ;)
  16. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    1. Early Hemi Tech
    thats rad...
    I cant wait to lite up my hemi with my joe hunt mag-
    Cool man...
    Tuck
  17. Paul
    Paul
    Editor
    I still catch myself looking for early Cad motors, even though I no longer have anything to fit one :rolleyes:
  18. CGkidd
    CGkidd
    Paul that's all you need is to branch out into the early cad motors.
