Blown 56 chevy gasser build for 2017 meltdown or bust
Discussion in 'The Hokey Ass Message Board' started by fast30coupe, Jan 19, 2015.
  1. CalGasser
    CalGasser
    Not running yet - waiting on my dual fans and throttle cable ***embly. How close are you?
  2. CalGasser
    CalGasser
    Absolutely correct, NEVER run an aluminum flywheel on a heavy car on the street! Experience is our best teacher...
  3. sch-1
    sch-1
    It's COOL dude!!
  4. Hey Fast30Coupe awesome build lots of get ideas car is coming together great. I'll be following your build. I am doing my Willys right now by have a 56 Sedan that is going to get the same treatment later. Hope to be putting a build of the Willys together soon on here so all can enjoy, working on the pic's right now. Keep up the great work looks to by a nice ride when done.
    elgringo71 likes this.
  5. fast30coupe
    fast30coupe
    from Illinois
    Thanks looking forward to that willys build
  6. fast30coupe
    fast30coupe
    from Illinois
    Far far away..... Needs to be running by July though.
  7. fast30coupe
    fast30coupe
    from Illinois
    Got a little time In the garage this morning.
    So I finished the upper shock mount on the drivers side
    And bolted the radiator back in
    Talked to the guy that's going to be building my roll cage he said bring the car in two weeks so hopefully that all works out.
  8. Saxxon
    Saxxon
    Coming together nicely...
    Jealous as hell about you guys working out of your garage. I am determined to insulate / heat mine so I can get stuff done over the winter rather than travelling all the way across town to get to the shop. The Scout is currently sitting patiently waiting for it's turn to get my attention.
    Cheers
  9. fast30coupe
    fast30coupe
    from Illinois
    There's no heat....haha. But, there's insulation. I just wear layers long underwear to keep warm. It ****s but what keeps me moving is knowing that if I waste weekends I'll never make the meltdown. I'll look up those articles that I was talking about later.
  10. Kail
    Kail
    from Austin, TX
    Looking good, keep it going!
  11. fast30coupe
    fast30coupe
    from Illinois
    Thanks I got a lot of inspiration from your build. I was going to run the stock control arms until I saw your thread.
  12. fast30coupe
    fast30coupe
    from Illinois
    Got a little time In today. I was hoping to bring my car in to the roll cage shop yesterday but that didn't happen. So, I rebuilt the rear trans mount for the jerico.
    Made a plate for the bottom of the transmission
    Then mad some plates to mount to the exiting transmission cross member.
    Then used a bent paper clip for a scribe.
    I littler grinding and welding
    Then finished off the back
    Here's a picture of it in the car I'm happy with how it came out.
    Also rolled her outside for some fresh air.
  13. cs39ford
    cs39ford
    That's one bad *** looking 56 good to see it in the fresh air. It's been a long winter!!
  14. fast30coupe
    fast30coupe
    from Illinois
    Thanks are you going to be racing yours at the meltdown this year?
  15. cs39ford
    cs39ford
    I will be there on sat with it. Will drive it up like last year. Want to run it one time to see what it will do. But got to get a different trans first that old weak sag will be the weak link. As for a street driver it's fine. So for now it's a street driver and a blast to drive. Going to racers expo next sat to see what's up there in the swap meet looking for one
  16. fast30coupe
    fast30coupe
    from Illinois
    What kind of trans are you looking for?
  17. cs39ford
    cs39ford
    M 22 Muncie or something along that line
  18. fast30coupe
    fast30coupe
    from Illinois
    I have an m-21 close ratio with a hurst shifter. If your intrested I had it for this car then I came across the jerico. It's rebuilt.
  19. fast30coupe
    fast30coupe
    from Illinois
    Started on the drive shaft loop today. It's only half way finished there will be 5 pieces of 1" tube that will be added for support.
    It looks far away from the trans mount but once the other supports are added it won't be that bad.
    cs39ford likes this.
  20. fast30coupe
    fast30coupe
    from Illinois
    Thanks I appreciate it. That was my though exactly it would've made for a short weekend at the meltdown.
  21. Inland empire hot rods
    from so cal
  22. saltflats
    saltflats
    from Missouri
    Racer X looks like he has that ****** under control.
  23. fast30coupe
    fast30coupe
    from Illinois
    Finished the drive shaft loop. Might be a little overkill but another thing off the list.
    Dog_Patch, loudbang and slammed like this.
  24. hep1966
    hep1966
    Looks great!
    fast30coupe likes this.
  25. Finn Jensen
    Finn Jensen
    Really some very, very nice work! Looking forward to seeing your car run in July.
  26. cs39ford
    cs39ford
    Again very very nice workman ship can t wait to see it in July
  27. fast30coupe
    fast30coupe
    from Illinois
    Waiting for the fed ex man for a speedway delivery so I decided to make the exhaust turnouts
    I bought my headers a year ago and I recently called they guy and he said he found the original caps in his moms garage so I went and got them a few weeks ago
    These haven't touched the headers in over 50 years.
    The turn downs are schoenfeld but they were hacked by some worker with the grinder and because nuts and wanted them to look the same I tacked then together before taking them to the belt sander.
    I did the openings and the collector side
    Much better
    Then cut a hole in the cap. My 3-5/8 hole saw was stripped out so I welded it the shank
    Here's the two welded together
    And on the car
    Dog_Patch, Butch M and cs39ford like this.
  28. saltflats
    saltflats
    from Missouri
    Looking good I like the idea of tacking the tubes together to make them even such a simple solution.
    Just curious on your ****** mount will be mounted solid and do you see a problem with that?
  29. fast30coupe
    fast30coupe
    from Illinois
    Thanks I didn't know it was such a problem until I ordered two different sets. I don't think the ****** being mounted solid will be a problem but we will see.
  30. saltflats
    saltflats
    from Missouri
    You have to watch out with a solid ****** mount if you have any ch***is flex it can take out the tail housing.
