blown corvair
Discussion in 'The Hokey Ass Message Board' started by rhandyman, Dec 8, 2010.
  1. rhandyman
    rhandyman
    from upland ca
    just thought you guys may want to see what a blown corvair looks like
  2. mrconcdid
    mrconcdid
    from Florida
    NICE, does that thing have a V-drive unit in it?
    If i remember there was a plastic model car kit, just like that back when I was a kid.
  3. resqd37Zep
    resqd37Zep
    from Nor Cal
    I was expecting something more like this
  4. gsp392
    gsp392
    I'd love to know how you did it.
  5. never seen 4 spoke daisy mags before. that blower sure looks the part poking out in the back.
  6. rhandyman
    rhandyman
    from upland ca
    this 471 blower is on a 164 ci corvair eng
  7. interstatemaster
    interstatemaster
    I like it!
    What are the heads you are using? I've seen the Corsa 140hp 4 carb heads but never a head with 3 ports in it. Did you make them or buy them? On the stock Turbo motor I never understood why the factory didn't use at least the 4 carb heads.
    How does it run? Any time slips? Runs with a G-Force?
    Fill us in.
  8. Spity
    Spity
    This should be a how to article on how to get your corvair to stop throwing its alt/fan belt!
  9. DD COOPMAN
    DD COOPMAN
    At least the belt(s) should stay on this one...like it! DD
  10. smarg
    smarg
    My brother's daily..
  11. metalshapes
    metalshapes
    Yeah, I've seen them a lot on Capri's, Cortina's, Datsuns, BMW's, VW's, etc...
    Maybe they are rare now, but they must have been pretty popular at some point.
  12. fleetside66
    fleetside66
    Hmmm..back in the 60's I had a stock Spyder, but some other dude had a Corvair with a Judson supercharger. He would run the thing at our local 1/10th mile packed dirt dragstrip & totally clean up. I like it ....I like it!!
  13. papajohn
    papajohn
    That's cool. But if that's what a blown Corvair looks like, what am I driving then?
  14. gsp392
    gsp392
    I'd love to see more detailed engine pics, ***embly process etc.
  15. rhandyman
    rhandyman
    from upland ca
  16. landseaandair
    landseaandair
    from phoenix
    Hey, where's the fan?
  17. rhandyman
    rhandyman
    from upland ca
    im using 63 turbo heads that i machined of the intake and welded on a tube for each
    port.isky 280 cam and forged pistons . i reworked a 250 ci in line 6 hei dist to fit the vair
    housing and pump drive, i now run a electric fan from a chevy citiation with air,
    the bat is now in the trunk and the bat box is now an over sized oil cooler and oil filter
    . it makes 6 pounds of boost under driven and 11 with the 1 to 1 drive. hay it kicks *** for a corvair
  18. rhandyman
    rhandyman
    from upland ca
    some people have a problem keeping a belt on a vair
    the trick is use the right belt. i get mine from California corvair
    i drive a 66 corvair rag top with a turbo and run the hell out and never kick a belt off of it
  19. RichFox
    RichFox
    My old boss had a home made sports racer with a mid engine Corvair and a B&M blower made for a 2.2 Chrysler. Thing ran good. Bet yours runs better.
  20. PacaRacer50
    PacaRacer50
    I was into Corvairs for years and still have a stash of parts for project down the road. Several of the corvair gurus have said the electric fan setup like the one you are running does not work. not enough pressure nor air flow to keep the cylinder heads from nuking the seats out. what are your experiences so far doing this and have you seen an increase in cylinder head temperature?
    PaceRacer50
  21. brett4christ
    brett4christ
    The 4-spoke "daisy" Americans were called "Libres", if I'm not mistaken.
    Cool'vair!
  22. ScottV
    ScottV
    Hey Nader ...
    Firetruck You !!!
  23. Dude, his is what a blown Corvair looks like, yours is what it SHOULD look like!!:D
    Doc.
  24. 3Kidsnotime
    3Kidsnotime
    from Utah
    Be interesting to see that engine on the dyno even that 4 takes some parasitic power to get moving...
  25. pretty neat set up. I want one.. except mine would have to be a convertible...
  26. seb fontana
    seb fontana
    from ct
    Why worry about "parasitic power" when the end result is more power? If the engine didn't have to drive the oil pump it would make more power also..:D
  27. 3Kidsnotime
    3Kidsnotime
    from Utah
    Be interesting to see the power curve.
  28. ganga
    ganga
    I want to see the wheels in the air!!!
  29. rhandyman
    rhandyman
    from upland ca
    just two more pics of my 64 vair
  30. terrarodder
    terrarodder
    from EASTERN PA
    Was that Tommy Knolf ? I had to run him at the fair grounds with my full flathead in a 34 2dr., made me look like I was going backward.
