Technical Blown Ford FE breathers and ventilation
Discussion in 'The Hokey Ass Message Board' started by Crown'd, Apr 30, 2017.
  1. Crown'd
    Crown'd
    from Utah
    What's the best means of ventilating a blown engine? Valve cover breathers, intake manifold vent tube, PCV valve, a vented catch can or a combination of the above?
    Esthetically four breathers on the valve covers hits right, a reminder of many scale models built as a kid. But those were quarter mile cars and this is a street car.
  2. Engine man
    Engine man
    from Wisconsin
    I'm partial to PCVs. The valve limits the vacuum on a blower that ****s harder than a normally aspirated engine.
  3. MeanGene427
    MeanGene427
    from Napa
    I have a couple buddies who have been running blowers on 390's for 10+ years on basically stock longblocks with great success, one on a 67 Mustang, the other a 64 Gal- and since I just came into a nice Weiand 8-71 setup yesterday, that's a good question to ask them
    Crown'd likes this.
  4. flamedabone
    flamedabone
    Run your PCV from the carb base to the drivers valve cover in front and use a vented oil filler cap on the p***engers side rear and you will be golden. Feel free to mix and match, but the idea is **** from the carb above the pressurized manifold and vent crosswise on the engine.
    -Abone.
  5. saltflats
    saltflats
    from Missouri
    I wouldn't think you would want crank case blow by going through the blower.
    I know I would't.
    Crown'd likes this.
  6. deathrowdave
    deathrowdave
    from NKy
    I have to agree , no blow by goin through the blower for me . Valve cover breathers and road draft tube for me
  7. Blown motors like a vacuum pump. We use Ford smog pumps around here.
    breathers on the rocker covers and vac to the crank case.
    saltflats likes this.
  8. Dean Lowe
    Dean Lowe
    Well baffled valve cover breathers have worked perfect for me for over 50 years on street motors.
    mad mikey and saltflats like this.
  9. flamedabone
    flamedabone
    You would think blow by through a blower would be a bad thing, but actually the blower doesn't give a ****. It is a positive displacement induction compressor, you could run an air/Kool-Aid mixture through it and it wouldn't care. The carbs mix the air/fuel, it is the blowers job to squeeze it tight enough to make more pressure below it than above it. The presence or not of blow by in the circuit does not matter.
    -Abone.
  10. gasser57!
    gasser57!
    Never had an issue with valve cover breathers on a blown motor for over 25 years. But I'm partial to simple and effective solutions.
    Sent from my SM-G900R4 using The H.A.M.B. mobile app
  11. mad mikey
    mad mikey
    Breathers are all that is needed. PCV? Its your choice, some guys use them on blown engines some do not. That subject has been debated to death. WIN_20150308_151943.JPG
  12. butchcoat1969
    butchcoat1969
    Jmo, but better to have them than to take a chance and not have them, I'd do what makes me feel comfortable and sure if my self lol, HRH
    Sent from my iPad using The H.A.M.B. mobile app HotRod Harry
  13. butchcoat1969
    butchcoat1969
    Love the look of that bad boy sittin in that hotrod
    Crown'd and mad mikey like this.
