Hot Rods Blown Hemi. What plugs?
Discussion in 'The Hokey Ass Message Board' started by junkyardgenius, May 29, 2017.
  1. junkyardgenius
    junkyardgenius
    from Kernow
    Getting my 354 Hemi back from the machine shop next week, got everything here to build a blown motor except for the spark plugs.Just wondering what other people are running?
  2. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    I'm going to START with an autolite #65......... RE=START.
  3. toxic waste
    toxic waste
    from Iowa
    Explain why you would use a autolite plug .
  4. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    I see you object......... My engine/My call. No need to explain.
  5. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Although not a blown 354, my dual quad 392 with 10.5to1 compression runs very well on Autolite 65 plugs!
    Autolite is still a quality plug and the right heat range for my Hemi.
    Some guys run Champion plugs, like some guys use Fram oil filters, as for me I wouldn't use either.
    Just my $.02.
    KK
  6. Kerry
    Kerry
    I run NGK V-Power plugs. Usually a #9.
  7. oj
    oj
    I prefer NGK plugs, very high quality at an affordable price. For the street I'd reccommend the 'projected' tip, it works better with the alcohol laced fuel, try an NGK FR5, stock# 7373, its' in the moderate heat range.
  8. dreracecar
    dreracecar
    from so-cal
    Too many questions--
    street or race
    type of fuel gas alc nitro
    injection or carb
    spark type magneto or standard ign
  9. Dave Covey
    Dave Covey
    Agree. I run a blown wedge mopar. # 9 NGK. Easier to read because of the cadium coating. With a hot ignition (mag or MSD) and running methanol it will like a cold plug especially on the track. Maybe not so cold on the street with gas.
    My .02
    Dave
  10. ngk -7 for me on gas.
  11. toxic waste
    toxic waste
    from Iowa
    No . I'm not objecting at all . Most people don't know why autolite plugs are used in blown engines.
  12. Marty Strode
    Marty Strode
    I ran NGK B9ES, and Autolite 4052, blown early Hemi on alcohol. The NGK's were easier to read, because of the plating would burn.
  13. I run the b9es for nitro. its a hot plug for nitro. the ground strap burns off shutting down that cylinder before it burns a piston. its a good plug to use on a new setup as the tune is figured out. I ran them in a late model bae hemi also.
  14. Ebbsspeed
    Ebbsspeed
    OK, I'll bite. Why don't you:
  15. 396_425
    396_425
    from Clovis, NM
    392 blown, 7 lbs boost, 4-port Hilborn, 1/2 110 octane and 1/2 premium and Autolite 65's, they work for me.
  16. lippy
    lippy
    from Ks
    Bruce, I have some AG903 Motorcrafts but I don't think that's what he needs. :p Lippy
  17. Ebbsspeed
    Ebbsspeed
    Why don't you share with "most people" the reason they are used in blown engines?
  18. Kan Kustom
    Kan Kustom
  19. toxic waste
    toxic waste
    from Iowa
    Autolite plugs are a good plug. There affordable to the point that when your tuning and racing, that you can replace them every pace. Read them and replace them. I help with a pulling tractor and every start up they were replaced.
  20. drumyn29
    drumyn29
    what is the best spark plug GAP on a blown Hemi with a Zig magneto.
