Hot Rods Blown sbc fitting into a 37-40 Ford?
Discussion in 'The Hokey Ass Message Board' started by Dreamweaver, Oct 1, 2017.
  1. Dreamweaver
    Dreamweaver
    Will a 6-71 blown sbc fit into a 37-40 Ford engine compartment using the current crop of commercially available engine mounting kits? Bottom blower pulley is 3" out from the balancer.
    I don't want to cut into the firewall. Anyone with actual pics of this?
  2. DDDenny
    Not sure if the engine bay is exactly the same as 37-40 but a guy down the road from me has a 41 Ford Sedan with a blown small block Chevy in it.
    Fits fine, didn't look at the firewall but other than the blower whine you'd never know it was in there, don't recall whether the engine mounts were purchased or built by owner.
  3. squirrel
    If it's a typical modern blower drive on it, with the 3" belt, keep in mind you can save an inch by going to a 2" wide belt. Might require a different snout on the blower, though. I run a 2" belt on my street/strip blown 427, seems to work just fine at 5 psi boost
  4. 42merc
    42merc
    I can't see it fitting into a '37-'39 standard. The radiator lays back at an angle, making things really close.
    '39 Deluxe & any '40 would accept a blower equipped Chevy easily.
  5. Dreamweaver
    Dreamweaver
    Ahhh a 2" belt, thanks Squirrel, guess I'll shop around for that setup.
    I haven't bought anything yet, car or blower, just trying to do some planning.
  6. Budget36
    Budget36
    Well, with a Hurst front mount, a SBC will have the back withing a scooch of the firewall...imagine a BBC would have to cut it, or think of moving things in the front forward...then there's the blower add-ons;)
  7. Dreamweaver
    Dreamweaver
    Can anyone with a firewall unaltered sbc equipped 39/40 Ford give me a measurement from the water pump mounting surface on the block to the face of the radiator, also which mounting kit/style you used?
  8. Tim
    Tim
    from KCMO
    IMG_9841.JPG This ones in a 40. Stole the pic from @Ryan maybe he's got more info
