blown up sir
Discussion in 'The Hokey Ass Message Board' started by tb33anda3rd, Jun 22, 2011.
  1. rougebeats
    rougebeats
    "Whats that noise coming from the mill"? "I dont know, floor it and see if it goes away". :p
    350 sbc is tried and true......with oil in it.
    fauj likes this.
  2. Bigjake
    Bigjake
    I once saw an SBC so hot the block and heads themselves were glowing a faint orange. I've seen many others get hot but never another block actually glowing.
  3. Deuces
    Deuces
    I took a close look at those pictures and noticed it was rebuilt once before.. Notice how clean it is??? Plus it's got a forged steel crank which can be saved by welding up all the jounals and re-ground them too stock specs... Well, at least we know it's been heat treated!... :eek::rolleyes:
  4. that's what the Ramchargers called a "Seasoned" block - you can make more power with it becuase they hold their dimensions better once remachined and they seal better - less bore distortion etc.
    Pretty tough way to do it though . . .
    VANDENPLAS likes this.
  5. In high school I worked at a gas station near a major highway. One day a '59 Ford came in, knocking so loud I could hear him coming from a long way off. The driver said something went "bang" a couple of miles back so he kept on driving until he found a gas station. When I opened the hood I almost laughed - it was a six cylinder and there was a hole in the side of the block you could stick your fist through, and you could look in and see the remains of the bottom end. Some people are just so stupid, and not just then but today too. I've seen cars with the hood hinges seized because nobody every opened it to check anything. Like somebody said earlier, "pay me now, or......"
  6. Andy
    Andy
    I used to car pool with another engineer. He had a LTD, maybe 10 years old. It used oil. He did not believe in putting any in as it would just burn it up. We were trying to get to work one morning and the light was on and the lifters were clicking. I asked if he was going to stop and get some oil. He said he was going to teach it a lesson. I suggested we put some oil in or we would be walking. It got one quart and we made it.
    Even knowledgable people are stupid.
  7. GlenC
    GlenC
    I had a call from a daughter one night...
    "Dad, the oil light's come on, what do I do?"
    "Ah, switch the engine off to start with... Now where are you".?"
    Drove out to her with a gallon of oil from the servo, not a trace of oil on the dipstick, and even the full gallon only brought the oil halfway up the stick. Turned it on, and away she went, (little Hyundai girlie car) but she didn't learn her lesson, because she did exactly the same thing to it 12 months later. These days I check her car myself.
    Cheers, Glen.
  8. My old girlfriend managed to blow up a slant six in the Scamp I bought her just before she left me - check the oil, what's that?
  9. G V Gordon
    G V Gordon
    from Enid OK
    I don't know but I've been told,
    Check your oil or you'll be towed.
    Sound off
    1,2
    Sound off
    3,4
    scotty t and Revived 265 like this.
  10. Flipper
    Flipper
    from Kentucky
    That pretty much sums up my biggest gripe with some people. You can expose them to important information, but you can't make them use it.
  11. tb33anda3rd
    tb33anda3rd
    knowing how tough the sbc is when after draining the little bit of oil out and finding it stuck, my plan was to put oil in it get it loose and get it running till we could locate an engine. even though iv'e seen it done in the past this engine wouldn't budge. i took the pan down and found what we see here. to get it turning so i could remove the torque converter bolts i had to loosen all the mains, all the rod caps, and remove the two front caps [with an air chisel]. to fix this engine i'm guessing, a crank and all the rods minimal, and boil the block out. any other suggestions?
  12. fab32
    fab32
    If I had a nickle for every one of those I've seen when I ran my old shop for over 20 years, I know I would have over a dollar in nickles.:(
    "You can lead a horse to water, but you can't make him drink":rolleyes:
    Frank
    kidcampbell71 and volvobrynk like this.
  13. [​IMG]
  14. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Ya just can't fix STUPID!!!!
    volvobrynk likes this.
  15. Deuces
    Deuces
    Yeah! You might have to spend all day getting the block line honed.. :eek:
  16. tb33anda3rd
    tb33anda3rd
    the auction he bought it at [BJ] stated it was a fresh rebuild and as Dueces noted it appears to have been. the motor did not leak a drop but according to the customer it "puffed" a little smoke.
  17. Deuces
    Deuces
    Yeah, I was able to tell by the numbered "stamped" dimples in the rod caps... Chevy never did that.. They might have stamped numbers 1-8 on them years ago, but then again I could be wrong...
  18. Deuces
    Deuces
    They probably used cheap rings an' valve seals to ***emble the motor with.. :rolleyes: Oh well!
  19. HotRod60F100
    HotRod60F100
    That engine is now for Barnacle Bill the sailor!
  20. Saxman
    Saxman
    Thanks for that useless comment. You're cool.
  21. BOWTIE BROWN
    BOWTIE BROWN
    1320/150
    You, my friend!! receive the douchebag of the day award!!! Congrats!!!
    bigbore1934 likes this.
  23. plymouth1952
    plymouth1952
    stone cold waste of a 4 bolt chevy:mad:
  24. tb33anda3rd
    tb33anda3rd
    where should i get a replacement? gm performance? jegs? big als toy box?
  25. propwash
    propwash
    from Las Vegas
    what a useless contribution you made....
    zzford likes this.
  26. Deuces
    Deuces
    If the customer is shelling out the sheckles, get it from the Chevy dealer!.. With a warrenty!!
  27. Ranunculous
    Ranunculous
    Guess that "Engine Restore" stuff wouldn't help right about now?That is sickening looking at those pics of the carnage?
    Like that guy's sig reads on here,"It ain't yours if it don't make you dirty?"
    I'm heading out to nut and bolt mine and check fluids...
  28. Deuces
    Deuces
    Don't ferget to use a torque wrench!!! :rolleyes:
  29. junkyardjeff
    junkyardjeff
    Time to put a good GM motor in it like a 472 or 500 caddy.
  30. gibraltar72
    gibraltar72
    from Osseo Mi.
    This guy could have benefitted from my grandfathers wisdom. He told my dad he didn't care how far he drove without gas but please don't drive without oil. Of course that was p***ed down to me by my dad!
    pat59, volvobrynk and scotty t like this.
