Boat Wiper motor??
Discussion in 'The Hokey Ass Message Board' started by 63bigbird, Nov 10, 2010.
  1. 63bigbird
    63bigbird
    Has any one used a electric wiper motor from a boat. I have a 1940 chevy truck that I am wanting to put a drivers side wiper on. I thought a boat wiper motor may work for the small size you can get them in and the different length shafts you can get. I know you can get specific kits for my truck but I don't want to spend a lot if this may work. Let me know what you guys think or any other motors that will fit in that small area.
    Thanks
  2. carcrazyjohn
    carcrazyjohn
    from trevose pa
    It should work ,Thats my plan for my 32 truck.
  3. Roy39
    Roy39
    i.ve used them on a couple cars--- a bit noisy but work great.
    and the price is right
  4. budd
    budd
    i have a found auto wiper motors at surplus places, princess auto here in Canada, but i;m sure there everywhere, i have mine on my 45 gmc, i just have it mounted outside the header for now and running the drivers only, but i have tried fitting it inside the header and will be able to run both sides, cost $20, two speeds and park
  5. lawman
    lawman
    Sounds like it may work. Worth a try. Tom (Tired Old man)
  6. gary9202
    gary9202
    For my old 69 scout...i bought marine wiper motors to replace the old vacuum ones. i paid 69 bucks a piece i believe and they work great and no noise outta them.
  7. kgdb
    kgdb
    from The 60"s
    member Tedley uses one on his 28 RPU. works great
    kgdb
  8. rustydusty
    rustydusty
    Scouts still had vacuum wipers in '69? Whoda thunkit!
  9. spooler41
    spooler41
    You may want to take a look at the a junk yard,check out rear window wipers on some
    SUV's. I snagged one for my closed cab mod. A p/u, not sure what it's off of. It came out of a pile of crashed parts, but it works and fits in the small space it needs to go in.
    .............Jack
  10. Dirk35
    Dirk35
    I too have heard of using a rear wiper motor from an SUV...... and I have sleep in a Holiday Inn before also!
  11. Used them in my 40 Olds coupe!
  12. 53sled
    53sled
    from KCMO
    I have a polaris wiper set i got for like $50. they aren't in time, but they work if it rains. I keep the p*** side turned off most of the time.
  13. NielsK
    NielsK
    from Denmark
    One thing to consider:
    They are made in different versions, most common type sweeps 90 degrees, or 110 degrees. It´s possible to find some that sweeps 135 deg.
  14. pasadenahotrod
    pasadenahotrod
    from Texas
    Not a problem, easier to find now than some years ago.
  15. 63bigbird
    63bigbird
    Didn't think of rear wipers, any suggestions on donor that is small enough for that area. Thanks
  16. I bought a chrome boat wiper motor with arm off FleaBay for $29. and put it in my truck. Still working like new two years later.
    Pictures in my on-line album.
  17. 302GMC
    302GMC
    from Idaho
    Find a wrecking yard that still stores parts in school busses. The '50s & '60s Waynes, Superiors, etc. use an American Bosch 12v motor that's no bigger than an avocado. If you want dual wipers, buy 2 ...
