Body filler abuse, I think we have a record!
Discussion in 'The Hokey Ass Message Board' started by Tinbender, Jan 19, 2006.
  1. David Chandler
    David Chandler
    That's armor plating, in case of a road side bomb!
  2. CheaterRome
    CheaterRome
    from URANUS
    The shop in which I work in recently re-did a 77 Cadillac Flower car or 77 Cadillac pick -em up truck whatever.
    The paint was bubbling in mid quarter panel...So I'm thinking "Hmm kinda strange."
    The whole rear quarter panels on both sides had bondo over 1 1/2 inch thick!!!!! All the body lines and character lines were created with BONDO , didn't even use chicken wire.
    Get this ....this was done by the FACTORY conversion from The "CoachBuilder"
    When we popped off the bondo it had a least a quart of water trapped underneath it on each side... Cut off the panels and created new ones... the originals were sooo rusty.
    Gotta love that 70's American automotive technology and craftsmanship.
    Jerome
  3. Tetanus Shot
    Tetanus Shot
    heres one i fixed last year, someone made an entire roll pan out of bondo on this 50 cadillac hardtop . . . some chunks were over 3 inches thick:eek:
    after
  4. beatcad
    beatcad
    the worst backyard, hillbilly, hack job i've ever seen was on a '62 caddy i brought home about 10 years ago. damn i wish i had pix now.
    a magnet couldnt even think about stickin' to the right quarter.
    apon further inspection(a little grinding than some tapping, than serious whacking w/ a 3lb mallet) the quarter was repaired w/ chicken wire, a schlitz beer can and bondo. WTF!!!
    you guys say "bondo" a lot. like it's a bad thing.
    bondo is a brand name like kleenex.
    douche bags or cheap guys may use "bondo".
    professionals will use a quality plastic filler and use it correctly.
    i was tought that you should do yer body work(hammer & dolly) untill it's pretty ****in' close to perfect. and filler is to finish off the rest.
    plastic filler should never be thicker than a dime.
    at least that is what i was tought.
  5. Zombie Hot Rod
    Zombie Hot Rod
    from New York
    It's really amazing how some of this stuff can be put on so thick over rusted out metal and stay in place for 10 or 15 years...
  6. fordcragar
    fordcragar
    from Yakima WA.
    I thought I had some good stories about some of the guys that worked in shops where I worked; but no, these are better. The only one I'll tell here is the guy that would pop rivet quarters on, because he didn't know how to weld.
  7. Michael Murder
    Michael Murder
    from Wyoming
  8. GlenC
    GlenC
    Had an old 1950's English Hillman sedan in the late 60's, had real bad rust right up the back of the p***enger front guard, where it joined the door pillar. Problem was the rust was DEEP, the pillar itself was rotten. I stuffed the hole full of paper and bogged (Aussie term for bondo) over the lot, then painted it so it would p*** its yearly safety check. I drove that car until the rust got so bad the p***enger door would fly open when I made a turn.
    Had a 1960's Falcon wagon in the 70's. The floorpans were rusted out so I scrubbed them back to bare metal (swisscheese) then fibregl***ed them and painted them with tar paint. Under the car I painted with fish oil then went for a drive on lots of dirt roads to cover the surface with dust. Looked good enough to p*** its safety inspection too.
    Cheers, Glen.
  9. happy hoppy
    happy hoppy
    nice job, looks like you saved that poor caddy Tet**** Shot.
  10. David Savary
    David Savary
    A few years ago my friend George asked me to look at his GTO. It had an early 396 in it and had developed a slight knock in the engine. I took out the motor and did bearings, curing the problem but noticed that the car sagged to the drivers side after. Never noticed that before. Had I done something to the car while doing the engine???!!! I went all around the car and checked everything. NOTHING! Until I washed the car. I was rolling down the windows after and couldn't roll down the drivers side rear window. A quick look with a flashlight revealed that the car was crushed in the rear and probably had 300 lbs of filler in the rear quarter! they had drilled it to make the filler stick, but never even made an attempt to pull it!
  11. On the 80 Z28 I have been working on (trying to get it done so I can sell it and make room) I found bondo in the stupidest places. And I had sent it out to a pro shop to get done. I am glad I went and picked up my car before they painted it.
    Where the p***enger side trunk lid hinge mounted was rusted away - and they just bondo'd it up. When you opened the lid the entire hinge moved. I started digging and they had 1/2" of bondo completely filling the well around the hinge. It had then been all sanded (must have taken forever since you can't get in there) and then hit with spray on gravel guard.
    Worst part was - I had given them a good hinge well I had cut off another car to replace it with and it was still in the trunk. Took me about 2 hours to fix it properly using the well sitting in the trunk.
  12. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I had an old 79 chevy pick-up truck that had bondo bottom doors on it when i was about 20. drove it down to Florida for Daytona bike week with my H.D. in the back. I get there and am wondering why the locals are all looking at my truck. Seems the road trip down there shook all the door bondo loose and there was no lower door skin at all, the bottom 9" of the doors were gone!
    some where on I-75 were some light blue door bondo patches big enough to take out a Peterbilt Grill.
  13. Landmule
    Landmule
    It's really amazing how many plastic filler sculpters are out there! My buddy had a 71 Camaro that was mostly constructed from shop towels and fibergl*** resin. It was really light and easy to repair!
  14. Camel
    Camel
    from oroville
    Rusty, I'll forgive you for the mild shot since you quoted Savage.
  15. Camel
    Camel
    from oroville
    Dang that hurt.
  16. zman
    zman
    from Garner, NC
    I think we still hold the concrete record though....
    rear seat riser on a customers '37 Chevy...
    after dipping...
    what came out of it...
    after we started repairing it (Justin is kicking *** on this thing)....
  17. Gigantor
    Gigantor
    And the winner by knock out in the 9th round .... Tet**** Shot!! DAY-UM!
  18. A saw a couple of concrete jobs almost as good as that one. One was online on a early 70's camaro. The entire rear frame rails were full of concrete and while the guy was taking it out - he even found some rebar added the the concrete frame rails!
    Betcha that car hooked good!
  19. HOT ROD DAVE
    HOT ROD DAVE
    concrete in a car, now ive heard and seen it all
    who in their right mind..........
  20. Oilcan Harry
    Oilcan Harry
    from INDY
    The guys tease our buddy about how he pretty much whittled a 68 Firebird convertable from a huge block of Bondo. Another guy's brother got screwed on a set of double hump heads he scored at a swapmeet. When he got around to hot-tanking them, the humps were bondo!
  21. BillBallingerSr
    BillBallingerSr
    from In Hell
    I have laid some fibergl*** that held up, prep is the main thing if you get it really clean and all of the rust killed and make sure the drainage is right it will hold. I did used to repair fibergl*** boats though. I had some holes in my toe boards on the floorpan and put 5 layers of cloth and resin down like you would a boat. The structural cross pieces were still strong, as was the metal I cut back to. Next repair will be new metal, but this is plenty strong and it won't rust again. It is a lot in how you patch it, getting it to bond completely so moisture doesn't collect is the key. But plastic filler itself is no thicker than a dime on the whole car. Blue filler is like paper. So far so good. I had a '68 Mustang that has been going for 20 years on a repair like that, the owner likes it fine, no issues.
  22. Squablow
    Squablow
    Picked up this gem to part out, had a 500 inch Caddy in it and some '36 Ford parts. The whole hood was made of cardboard, fibergl*** and wall plaster. Probably weighed 300 pounds. I defy anyone to beat this.
  23. ratt7
    ratt7
    Oh My ! I think their is a law against that sort of thing.
  24. It's funny cause it's true. LOL.
  25. 31whitey
    31whitey
    this is the FILLED ROOF of my 32 5w
    the DRIP RAILS as well[​IMG][​IMG][​IMG][​IMG]
  26. toddc
    toddc
  27. captainjunk#2
    captainjunk#2
    wow never saw so much body filer , lmao and concrete ? thats a new one , although a friend went to intall new frame rails into a 67 mustang and couldnt do it because someone had filled them with expandable spray foam , and gl***ed over them , car was a mess lol
  28. UnIOnViLLEHauNT
    UnIOnViLLEHauNT
    I can only imagine the bright cherry red brake drums on that thing while its driving around haha.
  29. Truckedup
    Truckedup
    About 15 years ago I decided my wife needed a sports car.I found a 63 MGB,a rust bucket and for sure there was body filler.But better than the filler was the floor of the car.MGB's are unit body and the entire floor,front to rear,side to side,including all suspension mounts was hand frabricated from 1/8 inch steel plate.All was smaller pieces welded together,nice welds too.The only original part was pretty much the ****** tunnel and firewall.The car appeared lowered cause it was probably 400 lbs heavier.I bought it cause the mechanical **** was in good shape.After a year I transplanted the mechanicals into a non rusted body.
  30. billbrown
    billbrown
    i built an entire dash board for a 62 cadillac out of sweat pants, resin and bondo. The guy who bought the car covered it in those giant crown air fresheners. There is also a batle axe mounted to the trunk, im VERY serious. It's always sad to see a previous car end up in the hands of a derelict.
