Customs Body filler question
Discussion in 'The Hokey Ass Message Board' started by oldsvroom, Mar 5, 2022.
  1. oldsvroom
    oldsvroom
    It’s been a while since I’ve done any body work . I’m building a custom now that will need some filler . What do you guys recommend for a good lightweight filler? Not bondo.
    Myself I use this... Easy to spread and sand
    Others may like different
    Bandit Billy, fauj, Dino 64 and 5 others like this.
  3. 1-SHOT
    1-SHOT
    from Denton
    That's one of the best body fillers around.
    Just Gary and loudbang like this.
  4. Hotrodderman
    Hotrodderman
    I have had the best luck over the years with Rage Gold. It sands well and I never have a problem with pinholes. It is the only filler I use. Good luck with your custom. Pics?
  5. My experience with fillers is they shrink.Ive done panels, shot primer,and been happy with it then looked a couple weeks later,and its pulled in leaving low spots. When I have to use it I try,and let it dry a few days before I sand.You can smell the solvents in the can,and they are going to evaporate as it drys.
    BJR and lothiandon1940 like this.
  6. Love Rage Gold. Upol has some great fillers as well.
  7. evintho
    evintho
    Another one for Rage Gold. That's all I use.
    Pat Thompson, Bandit Billy and BJR like this.
  8. gimpyshotrods
    gimpyshotrods
    Rage Gold is great.
  9. Dino 64
    Dino 64
    from Virginia
    Rage Gold :)
    Bandit Billy likes this.
  10. loveoftiki
    loveoftiki
    from Livonia,Mi
    3M Platinum Plus
    lippy, Bugguts and gimpyshotrods like this.
  11. fastcar1953
    fastcar1953
  12. ccain
    ccain
    Add me one to the list of Rage Gold fans for the body filler.
    Evercoat makes some great products.
    Their Metal Glaze is great for really dialing things in at the end.
    Bandit Billy and Tman like this.
  13. gimpyshotrods
    gimpyshotrods
    I use that now, but it does carry a price premium.
  14. lostone
    lostone
    from kansas
    I use and love fuzion.
  15. crider
    crider
    my go to's are rage extreme and 3m platinum plus
  16. Bandit Billy
    Bandit Billy
    I have used only Evercoat products on my current build and I have no objections. Rage, rage gold, polyester primer...excellent stuff!
  17. HOTRODNORSKIE
    HOTRODNORSKIE
    Rage is good stuff sands great but is big money. 3M bought the Bondo brand so the same stuff a lot cheaper,
  18. I really like this stuff, it’s probably the best I’ve ever used. Don’t think I’ll ever buy another brand. I like it better than 3m, ever coat and the rages, PPG’s. Do yourself a favor and try it.
    Poverty cap and Tman like this.
  19. gimpyshotrods
    gimpyshotrods
    Nope. Not even close to the same stuff.
    3M Platinum Plus and Bondo Brand are about as similar as an apple and a doughnut.
    Tman, da34guy and crider like this.
  20. gconnsr
    gconnsr
    from AZ
    I use the Evercoat Lite but you guys have me tempted to try the rage.
  21. oldsvroom
    oldsvroom
    Wow rage seems like a clear winner . Is there any real difference between the gold and ultra other than price?
  22. HOTRODNORSKIE
    HOTRODNORSKIE
    May be so but that's right from the 3M rep. All I'm saying is if you don't have deep pockets for the rage or the platinum might want to try the bondo. I have used it in a pinch and it's not your father's mud. I'll use rage every day and twice on Sundays but at 100 bucks a gallon it may be a bit pricey for the home guy
  23. K13
    K13
    Yes they are completely different resin technologies. The Ultra sands about 40% faster that Gold, has a denser surface structure so will absorb less primer and has the highest corrosion resistance of any filler on the market. It will survive over 500hrs in a salt spray booth pretty much everything else on the market is about half of that.
  24. 1-SHOT
    1-SHOT
    from Denton
    Maybe I should try Ultra. When Bondo first came out in the early 60's you had to surface it with a 36 grit disc if you did not catch it before it got hard. it was $12.00 @ case of 4 gallons. then other brands came out, so did the cheese grades.
  25. If the ultra is sandwiched between epoxy primers ,,, does the corrosion resistance matter ?
  26. K13
    K13
    Show me a collision shop that sandwiches filler between coats of epoxy.
    crider and 31Vicky with a hemi like this.
  27. Wasn’t a collision shops & high-end manufactures that started this idea/trend of epoxy first on bare metal , then filler then epoxy?
    The point of the question is if there’s epoxy on a metal sealing the filler what does and how much does it matter if the filler is extra corrosion resistant.
    Probably matters a bunch (500 hrs worth) for the cave&pave or wack&pack or the foam&filler guys.
    In the big scheme of things on a restoration project a few bucks extra in filler doesn’t matter much at all.
  28. modagger
    modagger
    I worked at the original Bondo plant in North Branford Connecticut one summer during high school.
    It was my job to bring the bags of “dry” product to the mixing vat where the “secret” pink stuff was waiting to be poured in.
    I asked the chemist in charge of mixing what the dry stuff was. He said, “basically it’s tal*** powder”.
    I got to take a case home every week for free. Thankfully I didn’t need to use it on my car but a few friends had what we referred to as “Cheese wheels”.
    427 sleeper likes this.
  29. 1-SHOT
    1-SHOT
    from Denton
    8F6B271F-52E9-47EB-AF26-FBA25AC909F2.jpeg You need to up your metal finishing abilities.
