Body mover
Discussion in '"The Antiquated" Classifieds' started by Andy, May 2, 2025.
  1. Andy
    Andy
    City: Kerrville
    State: TEXAS!
    Price: $150
    I work alone so have trouble moving things. I made this to remove bodies to work on them or the chassis. I could pull the body up and take it outside to blast or work on it. It is wide enough to clear the wheels on the chassis so you can roll the body away from the chassis. If you are space limited, you could just raise the body up to work on the chassis. It has two tubes with rope and hooks to pull the body up. There are holes to hold the tubes in position. There are notches to put 2x4's thru to rest the body on so the body is secure to move or work on. The tires are big enough to roll over rough ground.
    It is all put together with torx deck screws. Removing the two cross planks makes it fit into a pick up. I have loaned it out in the past. You could move it as is by adding a brace across the bottom.
  2. Andy
    Andy
    Somebody needs this
