1952-59 Ford body support question
Discussion in 'Off Topic Hot Rods & Customs' started by lincolnhead, Aug 12, 2015.
  1. lincolnhead
    lincolnhead
    from Marysville
    hi all its been awhile since i been on here. im just about to start the floor replacement and inner and outer rocker R&R. question though... how do you all support the body while cutting the all the floor stuff off? i need to replace my inner and outer rockers on the p***enger side and redo the whole entire floor...
    the body is currently back on the frame, any help would greatly be appreciated.
    thanks in advance,
    Chris
    welderdave562 likes this.
  2. mikhett
    mikhett
    from jackson nj
    weld square tubing between the a & b pillars on both sides .You can weld across from p***enger door to drivers door also.Thats the way i did it and it was on a rottiserie for 3 months.Check my profile for pics.
  3. Skeetum
    Skeetum
    I did mine on jack-stands with the body on the frame. Do one section at a time. Don't remove the whole floor at once. Be sure to treat all the exposed metal before covering with the new floors. Be sure your doors are aligned right, before you start, as the bottom edge will be your guide for rocker placement. Good luck!
  4. Texas57
    Texas57
    X2 on the one section at a time. My tunnel was in good shape, so I just did the "4 corners" one at a time. My doors were off though.
  5. Texas57
    Texas57
    By "my doors were off, though", I meant they were removed from the car, not off from being aligned.
  6. lincolnhead
    lincolnhead
    from Marysville
    thank all! I made sure my doors closed properly after jacking the frame up on stands. then did as you suggested and pulled the doors of and welded 1x1 inch sq tubing to the A and B pillars. let the fun begin :)
  7. fordsbyjay
    fordsbyjay
    from Lafayette
    I left the body on the car and shimmed it as close to the wheels as I could get. I fit the panels first and traced them to the original floor then did both sides of the front at the same time. I started in quarters but it seemed easier to make everything fit at the same time. I did the front first then the rear however. I coated the insides of the supports with a chemical similar to Phospho. Eats all the rust and seals them up (supposedly :) ). I have a page here somewhere with more detailed steps.
  8. lincolnhead
    lincolnhead
    from Marysville
    Thanks fordsbyjay! I dig it! I had to fab up a p***enger mount from scratch I couldn't find one online. ImageUploadedByH.A.M.B.1439872565.646006.jpg
  9. Mark T
    Mark T
    Jay,
    What brand floor pans did you use in the above post?
  10. HOTRODPRIMER
    HOTRODPRIMER
    Like Jay,I left the body in place and started cutting out the rust,fortunately it wasn't that severe. HRP
