Bodywork/Oil can?
Discussion in 'The Hokey Ass Message Board' started by slicknapier, Feb 26, 2013.
  1. msalamanca
    msalamanca
    X4
    do not heat then shrink it
  2. vega1
    vega1
    SlaP file and dolly
  3. rouye56wingnut
    rouye56wingnut
    from mn.
    I just got done making quarters for a 1946 chev panel that were 7 foot long . I cut out the inner panels to access the back of the weld so as to hammer and dolley the weld seam to STRETCH back out the shrunken weld line . I even came up with a slick dolley for the inside made from some metal and a piece of leaf spring . I then took a piece of 10 ft long 5/16 rod with a hoop made in the middle so that one half was inside the truck and the other was outside with a small 90 bent to fit in hole I drilled in the dolley . This allowed a helper to go inside the vehicle and push out on the dolley with the rod on it to act like a bullseye so that I knew exactly were to hit and stretch the weld .
    I also drilled a hole for my air chissel in the center of the dolley and had my helper on the outside this time with a large flat dolley to follow along as I was able to push out the sunken weld line as well as do some planishing as well . This all done after cutting down the pride of the weld on both inside and out as mentioned above . 013_13_1.JPG
  4. No no need to call, they seem to show up on their own. :rolleyes:
