Hot Rods Boling Brothers Brake Question
Discussion in 'The Hokey Ass Message Board' started by Mark Merritt, May 28, 2024.
  1. Mark Merritt
    Mark Merritt
    I've installed the Boling Brothers Brake Kit on my 36 Ford Roadster. Replaced 48 Ford backing plates with the 39-48 Kit (picture 1). The brake shoe retaining springs sticks out slightly past the edge of the 1 3/4" brake shoes about 1/8" (picture 2). So the spring retainer interferes with the backside of the wheel studs on the drums (picture 3). Has anyone run into this problem and if you did, how did you fix it? Already called Boling and all they could do was verify I have the right #8 pins for my kit. Thinking about putting a washer on the back of the backing plate where the retaining ring pin goes through but that will cause the spring to have to compressed even more.
  2. caprockfabshop
    caprockfabshop
    Never ran into that before, but I'd agree with your washer plan, that and/or removing a coil or so from the retaining spring to maintain a similar tension profile
  3. inthweedz
    inthweedz
    I've seen a heavy split pin used for the same application, adjustable to any length, and they worked good..
  4. 19Fordy
    19Fordy
    I don't see how cutting a spring coil will solve the problem as the pin length
    will remain the same.
    jaracer likes this.
  5. Oneball
    Oneball
    Those pins and springs are used on everything, the only real difference is the length, decide how much shorter it need to be and buy some the correct length. Googling “brake shoe retainer x mm” will come up with loads of options.
    brading and Tow Truck Tom like this.
  6. Oneball
    Oneball
    Ps is it me or is the right pin longer than the left one in the photo?
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Their telling you it is right does not make it so
    The proper length / height ( how ever you want to say it ) is what you need.
  8. Lone Star Mopar
    Lone Star Mopar
    Id keep it simple & try the washer plan first.
    Probably just another case of m*** produced product with poor quality control.
  9. Lots of room for compression on those springs. Shorter pins or your washer fix will work. Obviously the wrong length pins sent with the kit, regardless of the # on the pin.
  10. alchemy
    alchemy
    I bet it’s another case of mixing parts that never were intended to fit together. Some 36 drums on Lincoln brakes are few and far between. Henry never designed them together. I bet 39 drums would fit okay.
  11. caprockfabshop
    caprockfabshop
    If he puts a washer on the backside, and was concerned about the increased spring load on the brake ***embly, he could cut a coil off the spring to bring the load/distance back to roughly what it was before.
  12. Mr48chev
    One question, Did they say that they will work with wide 5 drums? or they intended to be used only with 40/41 drums? Looking at this drum I snagged the photo of off Ebay it looks like there is a lot more space for the springs right in that area. The "never had a problem" may mean that you are the first guy running wide five drums that has bought that set or the others just figured it out and made the changes to make it work. There a lot of inch and three quarter Bendix style brake shoes out there so finding shorter pins and springs shouldn't be an issue.
    As long as the springs don't have coil bind I don't see any issue with putting a washer or more on the back side of the backing plate take up space though.
    gimpyshotrods likes this.
  13. Mark Merritt
    Mark Merritt
    UPDATE PROBLEM RESOLVED: For anyone referencing this for the same problem in the future the backing plates I replaced were 48 Ford on which I was running 39 Wide Fives to accommodate the original juice brake conversion. To cure the problem I placed enough washers on the backside of the backing plate to bring the retaining spring to almost flush with the brake shoes. Any thicker and the spring is so tight shoes won't budge and I'm pretty sure they need to float some amount otherwise why not just put a bolt in to hold them down. Now the 39 drums turn freely. Thanks for all the replies with suggestions. And by the way the kit is correct with the #8 retaining spring pins which are 2". I also have a set of late 40 drums. I put them on before the washer trick and they had no interference.
    rod1, Lone Star Mopar and brading like this.
  14. RICH B
    RICH B
    How does the unusual use of a two piece wide 5 drum that is causing the interference with an otherwise standard ***embly equate to "poor quality control" on Boling Bros part?
    Blue One, 1946caddy and gimpyshotrods like this.
  15. gimpyshotrods
    gimpyshotrods
    This kit was not designed or intended to be used with Wide-5 drums.
    They work perfectly with later drums.
    Lone Star Mopar likes this.
  16. gimpyshotrods
    gimpyshotrods
    Nope.
    These folks don't sell junk.
  17. brading
    brading
    It is always good when the OP explained how they solved a problem they have posted about with the help of fellow Hamber's
  18. Blue One
    Blue One
    from Alberta
    It’s even better without comments like bad quality control or allegations of bad information from the producers of the kit.
    Or wrongly telling someone to cut coils off of the springs.
    That sort of Mickey Mouse engineering doesn’t work for suspensions and it doesn’t work for other coil springs either.
    Boling Bros/ MT products sell a top quality brake kit.
    I know, I’m running one on my 26 RPU.
  19. Lone Star Mopar
    Lone Star Mopar
    @RICH B @gimpyshotrods @Blue One
    No no no... I wasnt referring to Boling Brothers selling poor quality products. Im up to speed on thier work. My bad if it came accross that way.
    I was ***uming those little spring retainer pins were probably m*** produced in an offshore factory by the millions and might just be a bit "off" standard.
    Im sure yall know that is plenty common in dealing w aftermaket parts, new parts ect..
    My post was geared towards getting the OP Marks brake job moving forward. Not throwing shade on the B.Brothers or thier kits.
    Its all good my brothers. Im glad the problem is solved ! Im on the HAMB to learn, help out where I can, & crack jokes w my buds. In this instance I was trying to be helpful, & learned something too. :cool:
    Blue One likes this.
  20. Rockchip
    Rockchip
    Good that your problem is resolved. Oddly, I had the same problem with their backing plates and their drums. The spring retainers stuck out past the shoe. 3 flat washers under the pin head cured the problem and we're closing in on 20,000 miles since. BB BRAKE PIN.jpg
  21. manyolcars
    manyolcars
    The only thing bad about their kits is -- no self adjusting parts are included
  22. Blue One
    Blue One
    from Alberta
    As it should be. No self adjusting parts were on the originals that these kits are a re creation of.
    HemiDeuce likes this.
  23. RICH B
    RICH B
    Seems weird they would have used a #1 pin; those are usually for 2-1/4" wide shoe. I can see why they stuck up too far.
    I use #4 pins for 2" shoes and #2 pins for 1-3/4" shoes.
    HemiDeuce and Tim_with_a_T like this.
  24. uncle buck
    uncle buck
    Getting a shorter pin would be an easy fix in my opinion.
    Silva likes this.
