Technical Bolt grade markings
Discussion in 'The Hokey Ass Message Board' started by atch, Sep 26, 2025.
  1. atch
    atch
    Before the search police come to arrest me let me tell you I **** at searching and I've already tried.
    What can you tell me about this bolt?
    I need 3 just like it but 3/8" shorter.
    I'd like to just buy them and have new. If I have to I can cut these down (cheap/free and I can do it right here without making a trip to town). If I cut these off will the resulting heat ruin the bolt strength?
    Sharpone likes this.
  2. 1934coupe
    1934coupe
    What size are they? Is that a flywheel bolt? 3/8-24 maybe.
    Pat
    GlassThamesDoug likes this.
  3. Looks like grade 8 Ford flywheel bolt.
  4. twenty8
    twenty8
    They are a type of self-locking bolt called "Place bolts". They resist loosening due to vibration better than traditional bolts. A common use is for flywheels and flexplates.
    Try and get an in focus pic of the head so we can see any markings.
  5. squirrel
    that might depend on how you cut them? A hack saw won't get them as hot as a cut off wheel. And the cut off wheel will only get the end hot, it won't affect the strength of the rest of the bolt noticeably.
    the more details you give about what you're doing, the more helpful we can be. What are you using them for?
    btw it looks co**** thread to me....so not a flywheel bolt.
  6. BigRRR
    BigRRR
    GuyW, tb33anda3rd, Robdski and 5 others like this.
  7. atch
    atch
    These are 8" Ford rear bolts from the front. Pinion housing not the dozen or so studs that hold the third member into the rear housing.
    This 3rd member that I'll be using had some kind of 3/8" thick bracket attached to the front that used 3 of the 4 bolts.
    I'm typing this on my phone from bed. I'll take more pix tomorrow. As for markings you are seeing everything. A more focused pic won't show any more than these. To get a more focused pic the bolt will be smaller. But, I repeat, there are no more markings.
    Tim and Sharpone like this.
  8. BigRRR
    BigRRR
    The link I posted stated that place bolts are SAE grade 8 …
  9. abe lugo
    abe lugo
    Has anyone ever seen and Z marked bolts and does they have any in hand? 3/8 bolts about 1-1/4" long
  10. twenty8
    twenty8
  11. atch
    atch
    My phone wouldn't open the link. I'll try on the desktop tomorrow.
  12. twenty8
    twenty8
    Zinc plated...???
  13. squirrel
    Cut them off and don't worry about it.
  14. Jagmech
    Jagmech
    The grooves are formed during manufacturing process, some are asymmetrical and others may a large depression in the center, trying to duplicate with sawing or grinding will only weaken the bolt.
    alchemy and Sharpone like this.
  15. saltflats
    saltflats
    from Missouri
    Cut them off as stated above^^
    seb fontana, Sharpone and manyolcars like this.
  16. '29 Gizmo
    '29 Gizmo
    from UK
  17. Those are the typical "place bolts" that Ford and others used in strategic places. The bracket you are referring to is probably a "bump stop" bracket that Ford used on some of its intermediate cars. 3 options-
    1. Cut the longer ones off- I clamp a nut in a vise, thread the bolt in so it can be cut off square, and cut it with a hacksaw.
    2. Buy 4 new grade 8 bolts the proper length and use either a grade 8 lock washer or use lock***e.
    3. I have a pile of 8" rears- let me know the length and I will send you some.
  18. Joe H
    Joe H
    Pontiac and probably others used bolts marked like that for P/S brackets, A/C mounts, water pumps, and anything they didn't want to vibrate loose. I have some also, what length and thread do you need?
    GuyW and Sharpone like this.
  19. RodStRace
    RodStRace
    Thanks @BigRRR and @twenty8 ! I'd run across them before and knew they were location specific, but didn't know all the details. Neat stuff.
    Robdski, Sharpone, twenty8 and 2 others like this.
  20. atch
    atch
    To everyone who took your time to read, think about it, and respond I'm indebted.
    Thank you all.
    The link opened on my desktop. Thanks for the link. This is new information to me. I had never heard of or read of this.
    Robdski, BigRRR, RodStRace and 2 others like this.
  21. twenty8
    twenty8
    For all of you that are thinking "I have seen those type of bolts somewhere but I just can't seem to put my finger on it........"
  22. Sharpone
    Sharpone
    WOW learn something almost everyday here. Like many I’ve seen these bolts before however didn’t know they were self locking.
    Thanks all.
    Dan
    RodStRace likes this.
  23. Actually, the underside of the head is concave and acts like a Belville washer when tightened. Pulled 3 this morning for Mike.
    Tim, RodStRace and Sharpone like this.
  24. RodStRace
    RodStRace
    Yeah, one of the links posted explained this.
    Maybe it's just hindsight, but I do remember that those bolts do torque up with a different feel and the explanation makes perfect sense.
    Oh, and good on ya for helping a fellow HAMBer!
  25. Tim
    Tim
    from KCMO
    Good information! I’ll have to put a few of those same bolts to bolt on a pan hard bar to my 8”
    did anyone come up with a source for new? Sounds like grade 8 with a cupped washer would be a good replacement if needed?
  26. RodStRace
    RodStRace
    This says they have them, but want you to provide info for a quote
    https://wilsongarner.com/products/placebolts/
    This one lists suppliers
    https://www.fastenersclearinghouse....lts&Cat1=PRM460D65E02814;&Cat2=FLFEE664B5226;
    This one lists them in large quan***ies
    https://www.aftfasteners.com/place-bolts/
    Grainger and Fastenal didn't show them just searching for 'place bolts'.
    Judging from the common uses in automotive (flywheel and ring gear) they seem to be for a low clearance very solid high torque part-to-part usage. I'd say a suspension bolt would be better served with a regular bolt and lock washer.
    seb fontana likes this.
  27. uncle buck
    uncle buck
    I’ve seen those used on lower crank pulleys on 60’s fords
  28. ClayMart
    ClayMart
    Quite a few years ago I recall seeing a few Bowman brand bolts that had 12 hash marks on the heads. They were referred to only as BowmAlloy but I've never seen a more standardized grade rating for them. The bolt heads were pretty normal looking, not like the place bolts shown above. Never seen an automotive application use them. Maybe for industrial or HD trucks. Always wondered how they were rated compared to a more common grade 8 bolt.
  29. twenty8
    twenty8
    The configuration/shape of the bolt head allows it to flex during the torqueing process, causing a spring clamping force that keeps the bolt tight. They are used in places where there is rotation/vibration and you want things to stay tight, especially places that are hard to inspect and get into to check and re-torque the bolts (eg: ring gears, flexplates, etc).
  30. lostone
    lostone
    from kansas
    What do you guys thing about drilling holes thru the head for safety wire?
    Thought about doing that on my truetrac in my Ford 9"...
