Bolt in head problem
Discussion in 'The Hokey Ass Message Board' started by 383deuce, Jan 20, 2014.
  1. fsae0607
    fsae0607
  2. nunattax
    nunattax
    http://www.rbmindustrialsupplies.co...-Rost-Off-Ice---400ml-Rust-Removal-Spray.html .
    you could try this , heat the head and spray the bolt .try out 1 1/4 turn in 1 turn.repeat process over and over.take a break.start over.use 1/4 drive ratchet no extension short reach socket. , go easy.those arp bolts are hard stuff.i wouldnt try to drill without a guide of some sort.special stainless drill bits are available.i would rather strip the thread and helicoil it than drill it though.good luck
  3. whooo-hooo
    Bet you are doing the happy dance
  4. Not bustin' your chops 383deuce, I can't imagine anyone thinking stainless hardware for header bolts is a good idea. I avoid stainless for structural usage like the plague. If you want shiny, buy chrome bolts.
    31Vicky with a hemi, Most thread locker is heat removable so it doesn't do much around headers, best bet is safety wire or some other mechanical lock on header bolts. Yes I know, pain in the ***!
  5. fsae0607
    fsae0607
    Those Stage 8 locking header bolts work very well. I have them on my O/T vehicle with headers. Set 'em and forget 'em.
  6. nunattax
    nunattax
    that was quick , older and wiser
  7. blowby
    blowby
    from Nicasio Ca
    Run a tap in there in case you fouled the threads.
  8. R Pope
    R Pope
    WD40 is useless as a penetrant, it's a water displacer.
  9. nunattax
    nunattax
    also a lubricant,got me outa some tight spots.but i wouldnt take it to bed with me
  10. fsae0607
    fsae0607
    ... and good to clean your tools with!
  11. It's unstickied a bunch of stuff for me
    And removed some really ugly glue off some very expensive cabinets.
  12. fsae0607
    fsae0607
    WD-40 works okay as a lubricant. I think of it as a "jack of all trades, master of none" type liquid. Go on their website and see their 1,000+ uses for it. It won't work as well as a dedicated lubricant or penetrant, but nevertheless still good to have in your toolbox. WD-40 and duct tape are ALWAYS in my on-the-road toolboxes!
  13. 383deuce
    383deuce
    Just so ya know I did run a tap in it a couple of times and blew it out good with airhose. The bad thing about all this was I was just installing the header for mock up of my steering shaft. I was not going to tighten it down. I would never use a SS bolt for the completed build. Sure did not think it would hurt anything for a few hours of mock up....Little did I know.
    But I am a HAPPY, HAPPY, HAPPY guy now. PS. SS bolt is now in the trash can.
  14. big duece
    big duece
    from kansas
    I got a intake manifold bolt set in stainless, you wana try your luck with those now that you know how to fix it??
  15. So why mockup with all the bolts?
    I use just 2 most of the time.
  16. You did install all the bolts right? for a mock up :confused:
