Bolt on Rear ends on stock frames Chassis Engineering etc.
Discussion in 'The Hokey Ass Message Board' started by Brooding Swede, Jan 27, 2004.
  1. [ QUOTE ]
    [ QUOTE ]
    4t64rd: Hey thanks what did you mean? "the rear shackle goes through the framerail. " does it go in the frame channel? Thanks, BS
    [/ QUOTE ]
    The top bolt of the shackles in the rear have a 1-1/16" hole drilled through the fram rail, a bolt-in bracket has a length of tubing welded to it that the rubber bushings fit into. The end of the spring moves back and forth about 1/4" below the frame rail. Next time I go over to the shop I'll bring the camera and take a picture and send it to you. It wouldn't be hard to duplicate. The kit also uses Dodge truck springs, because they are the same length from the nub to each end. The front mount bolts-in and connects the framerail to the x-member. If you want, I can send you the catalog from a few years ago, prices won't be right, but it's free.
    [/ QUOTE ]
