Bolt pattern decision....?
Discussion in 'The Hokey Ass Message Board' started by Chris 50, Sep 29, 2005.
  1. Chris 50
    Chris 50
    I'm on the verge of ordering a ch***is for a '36 Ford I own. It is offered with either a 5 on 4 1/2" or 5 on 4 3/4" pattern standard. I'd like to run my old 1940ish 5 on 5 1/2" 16" steelies. They want about 700 bucks for the odd pattern. Does anyone make the same wheels with the smaller bolt circle? Either way, it seems as if I'd have to shell out the money for the different pattern or a set of wheels.......unless there is a front disc with a 5 1/2" bolt circle that will bolt onto a Mustang II. Anybody?
  2. Django
    Django
    from Chicago
    I think Stockton (but we don't like them) or Paul Paulen might have a wheel that will work for you. Try their site.
    And bring me that damn dash. I have one in primer all ready for you. :D
    Whose ch***is?
  3. Squablow
    Squablow
    Get the 4.5" bolt pattern and use some 40's era International rims on it, they're skinny 16" they take a 6.00 16" tire and you can run the Ford caps on them. You can sell your 5.5" Ford wheels to pay for the IH ones. If you can't find those, 40's Mopar wheels are also 6.00-16" with the 4.5" bolt pattern, that's what my '40 Chrysler had stock. Chevy had 6 lug in the 40's so the 4.75" bolt pattern won't mate up to any early wheels.
  4. HemiRambler
    HemiRambler
    7 bills to change the BC??? If it were me I'd go find ANOTHER supplier - in my book that's clearly gouging. But then again - I'm goofy like that.
  5. Chris 50
    Chris 50
  6. Chris 50
    Chris 50
    Django, it's a TCI.
  7. mojo66
    mojo66
    NOOOOO!!!!!!! Haven't you seen the post about Stockton? Almost nobody had ANYTHING good to say about them.
  8. Chris 50
    Chris 50
    Bad product or long wait time? It's not like I'm in a hurry for them.
  9. carkiller
    carkiller
    Buddy of mine has been waiting two months for a pair of chromies to be replaced. His run out of square about 1/8 inch.
  10. Dirty Dug
    Dirty Dug
    Wheel Vintiques sells the wheels you're after
  11. Well guess Im just Ole Skool.
    When I found out I couldnt use the 52 merc fronts, to match my rears. I settled for 40 fronts. I sawed, and ground the stock studs flat. made a template form the rears, and drilled and added studs.
    My 40 drums now have 53 small bolt pattern.
  12. Chris 50
    Chris 50
    I looked a bit at Wheel Vintiques, and the series 14 gennie looks like what I'm after. How's their product and service?
  13. Thirdyfivepickup
    Thirdyfivepickup
    I've heard some good stuff about them. One of my rod shops uses lots of their stuff and doesn't have any trouble.
    I'm pretty sure the wheels Pops is putting on the 35 are coming from them. We know Pops only buys the best.
  14. dodgerodder
    dodgerodder
    Not sure what size and width smoothies you're looking to run, but 98-present S10 spare tire rims are steel smoothies that are 16x4.5 or maybe 5" wide, and are 4.75 on 5. They are readily available and cheap. Just a thought, maybe worth checking out
  15. AnimalAin
    AnimalAin
    I got wheels from Wheel Vintiques a few years ago. Very satisfactory service, and product exactly as advertised.
  16. InDaShop
    InDaShop
    from Houston
    I've been pondering a purchase from them. Glad to hear the service is good, and product is quality. I'm not at all excited about the cost. Thats why i'm still pondering. I want these oddball spokes but they are $600 a pop!!!!!
  17. thatredcaroutside
    thatredcaroutside
    from Decatur,AL
    I've been running their OE Reverses for 6 years with no problems. 60-70K miles.
