Technical Bolt pattern on a 1945 dodge pick-up?
Discussion in 'The Hokey Ass Message Board' started by Baileygreen, May 4, 2014.
  1. Baileygreen
    Baileygreen
    I'm trying to get some wheels for my 1945 dodge but I don't have a clue on the bolt pattern. If anyone knows it would be appreciated!
  2. truckdog62563
    truckdog62563
    Half ton is 5 x 4.5". Three quarter could be 5 x 5" or 6 x 7.25". Power Wagon is 5 x 6 7/8" circle. Stu
  3. Baileygreen
    Baileygreen
    Thank you so much, it is a half ton. The reverse bolt pattern should be a issue when putting wheels on should it?
  4. Baileygreen
    Baileygreen
    Reverse thread*
  5. truckdog62563
    truckdog62563
    Reverse thread? Do you mean you have left hand threads on the driver side and right hand threads on the p***enger side. Normally the nuts in such situations are marked "L" and "R". Stu
  6. Exactly how many more times do you plan on asking the same stupid question. I count 5 times, so far. You've gotten the answer multiple times. Go buy the wheels, for cripes sake
  7. Rusty O'Toole
    Rusty O'Toole
    Plym/Dodge/DeSoto/Chrysler wheels to 1970 will fit. Others will need to have a hole drilled for the alignment pin, even if they are 4.5X5 bolt pattern. Take a portable drill and 5/16 or 3/8 bit.
  8. whtbaron
    whtbaron
    from manitoba
    Any reason why you shouldn't grind off the pin instead of drilling the wheels?
  9. mcmopar
    mcmopar
    from Strum, wi
    I have seen this question twice at least. I pm'd you with all the info you should have needed 2 weeks ago. They will not change themselves, get out there take a wheel off and start measuring.
