Bolt Pattern
Discussion in 'The Hokey Ass Message Board' started by Slick Steve, May 8, 2010.
  1. Slick Steve
    Slick Steve
    from Indy
    I have looked everywhere, and googled every way I can think with no luck. I am trying to find out if the bolt pattern on my '51 Dodge Wayfarer stock wheels are the same bolt pattern as Ford. I want to buy Spider caps and am trying to find out.
    Thanks for the info!
  2. Master of None
    Master of None
    Measure from the outside of the stud to the center of the stud directly across from it. If its 4 and 1/2 its Ford 4 and 3/4 Chevy.
  3. stillrunners
    stillrunners
    from dallas
    Mopar cars and trucks...are 4 1/2 all the way up...Ford cars start 4 1/2 at 1949 up ...look out for big Chyslers and big Ford cars...
  4. Blown Mopar
    Blown Mopar
    from abc
    Many Chrysler products use the same as Ford at $1/2". A tire shop should be able to tell you if yours are 41/2. There is a handy gauge that can be used to detyermine your bolt patteren size. The inexpensive ones are made of plastic: you might find one at better parts houses.
  5. MercDeuceMan
    MercDeuceMan
    from Indiana
    I have a bolt pattern gage I can send to Bubba's with the wife on Monday if you want. Just let me know.
  6. Hnstray
    Hnstray
    from Quincy, IL
    If it's original, it's 4 1/2" bolt circle............
    Ray
  7. hdman6465
    hdman6465
  8. 51 MERC-CT
    51 MERC-CT
  9. R Pope
    R Pope
    Mopars used the 4 1/2" pattern from the '30's on, except for Imperials and '83-up trucks. Same as '49-up Fords, but the alignment dowel has to go if you want to use Ford wheels. Or drill out the threads and put studs in the hubs.
