Hello, I need to know the dimension of bolt (Diameter and length) for the support of the transmission as well as bolt for supports of engine. Because I do not have them. The problem is the unit : inches for you and milimètres for me. If I know the good dimension, I can order it in USA. Excuse my bad english it's verry difficult to speak about technic... Rémi
Measure out what you need in millimeters and divide by 25.4 - that should give you an answer in inches. You can get American hardware from the Caterpillar Construction Equipment dealer - use this catalog to identify: http://www.cat.com/cda/files/87031/7/hardwre.pdf
