Bondo removal?
Discussion in 'The Hokey Ass Message Board' started by louder50, Nov 1, 2005.
  1. louder50
    louder50
    from Michigan
    Hi guys, probably a stupid question but I am very new to this. Is ther an easy or preferred way of removing bondo? I have a 49 Chevy coupe that someone tried fixing a dent in the rear quarter on. They just ****ered bondo on it and didn't do a nice job, how do I get it off/out? DA? Sandblast? stripper of some sort?
  2. 40StudeDude
    40StudeDude
    Use a propane torch...heat it, from the backside if possible...if not at the front will work...use a s****er or a screwdriver...it'll come off easily!
    R-
  3. Bugman
    Bugman
    I second the torch. It'll burn and stink like hell, but it flakes right off with minor effort.
  4. SwitchBlade327
    SwitchBlade327
    ditto on what they said, but use one of those heavy duty gasket s****ers if you have one, they work *****in'.....
  5. Squablow
    Squablow
    You can buy the little propane torches at a hardware store for like $15 if you don't have one.
    a 5" disk grinder would work fine if you don't want to play with fire. Just don't grind on the steel too much, just enough to take the filler off.
    Don't use a DA, you'll be at it forever.
    Paint stripper will soften up bondo, but only a 16th inch thickness or so. If you had a super large area with a super thin coat of mud on it, paint stripper would work, but usually that's not the case.
  6. Sixcarb
    Sixcarb
    from North NJ
    Grind it out, if you have a regular size grinder it works just fine just a bit dusty.
  7. Bugman
    Bugman
    If it's a big enough dent with enough thick bondo, you can just smack the backside with a hammer and it'll crack off.
  8. Crankhole
    Crankhole
    Just put another 1/2" or so over it and smooth it out.:D
  9. Slag Kustom
    Slag Kustom
    if you cant get behind it to use the torch a twisted wire brush cup on a angle grinder will take it out pretty quick with out disturbing the metal.
  10. sparky65
    sparky65
    from st. louis
    grind that **** out, either a D/A or a grinding disc it wont take long, don't use a torch, i you do that you might warp the metal.
  11. HardLuck
    HardLuck
    I used one of these multi-strippers on a huge wad of bondo that was on my truck's door when I got it.
    Worked really well for me.
    -HL
  12. bbo
    bbo
    from Wylie, Tx
    torch. mind the heat though warpage is possible. If you heat the filler it is slower but will not warp as easliy.
  13. pimpin paint
    pimpin paint
    from so cal
    Hey,
    What ever method ya go with to remove the filler, be sure ta
    use a full face shield when grinding or usin that wire flap wheel
    deal. Hot roddin' just wouldn't be much fun with a patch over your eye!
  14. PONY
    PONY
    A few months on the fine, fine roads here in downtown Seattle knocked out all the bondo on the lower quarters of my 53 Ford. In places where I didn't even know there was bondo! Our roads ****, But we got two new sports stadiums..
