Event Coverage Bonneville Speedweek 2025
Discussion in 'The Hokey Ass Message Board' started by Rand Man, Jul 31, 2025.
  1. Rand Man
    Rand Man
    akoutlaw, lurker mick, aircap and 2 others like this.
  2. Rand Man
    Rand Man
    One more thing about B***. He had the honor of carrying the ashes of Gene Winfield for one last ride on the salt. I think it might’ve been the run where he spun out at about 180 so Gene got a wild ride. IMG_1771.jpeg
  3. Mr48chev
    Several cars carried some of Gene's ashes on a p***.
    Pretty much in the way that we gave one of my boating mentors a send of at Port Townsend Wa in 2008. At his daughter's request those with black powder canons and that number was 12 put a small packet of his ashes in each canon and fired them off at 12 Noon.
    Gene loved land speed racing at any level and having his ashes spread on the salt is fitting.
  4. 19Eddy30
    19Eddy30
    from VA
    Just asking Never seen / been to land speed in person ,
    When these Cars spin out , How do they Not Dig In & Tumble ?
    Or these the Lucky one's that just
    Spin & Slide !! ??
  5. Hollywood-East
    Hollywood-East
    The God's of Speed determine that..
    But a Key thing most don't realize, These cars are built Very heavy, An have that weight as low as possible..
    An a **** load of Luck goes a long way
  6. 19Eddy30
    19Eddy30
    from VA
    Thank you ,
    Is there a weight minimum / requirement per cl***
    Or Up to Racer / Builder ,
    Let say B*** car Weight Minimum
    Like 3,500 plus ?
    Or Weight determined by Speed Mark Minimum shooting for ?
  7. Hollywood-East
    Hollywood-East
    Someone will chime in...
  8. RodStRace
    RodStRace
    My limited understanding is that cl***es are engine type and size (and fuel) paired with body.
    Unlike almost any other racing, weight does not factor into it for the rules or running (no gain for 100 pounds less).
    Weight helps with traction and stability plus strength.
    This shows cl***es, the only mention of weight is electric/turbine
    https://bonnevilleracing.com/vehicle-data-codes-cars/
  9. Ken Smith
    Ken Smith
    Alliance Vendor
    There is no weight minimum or maximum for all the cl***es out there, with the exception of the prior mentioned electric turbine things. Each racer determines how much weight he needs to gain the traction that he wants. Traction is a major problem out there. Sometimes it’s like driving on hard packed snow. Roadsters have the aerodynamics of a brick, so if it spins sideways, it will probably slide. Door slammers will sometimes fly, like in nascar. They run high tire air pressure to reduce the tendency for the tires to roll off the rim. It’s a combination of slick surface, low center of gravity, poor aerodynamics and hard tires that luckily have most roadsters do a flat spin instead of a tumble. Exceptions apply. The 911 roadster tumbled this year. I’m not proud of it, but I’ve spun a roadster a few times in the 180-200 mph range. I was fortunate each was a flat spin.
    rod1, Rand Man, 28rpu and 9 others like this.
  10. Mr48chev
    One thing is that the tires don't normally have a lot of tread or sharp endges on them that dig in.
    Stan Back and saltflats like this.
  11. jimmy six
    jimmy six
    And if they come with them like some Vintage Dunlops…..you sand/grind them off.
    Stan Back, Ken Smith and saltflats like this.
  12. Marty Strode
    Marty Strode
    All true, my brother's OT 90 T-bird weighed 6200, he still got some serious air a couple times, but landed on all 4's.
    Jalopy Joker, rod1, dwollam and 3 others like this.
