Projects Bonneville XF/GMR Build
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Sep 14, 2021.
  1. Never too purdy to race!
    Best looking roadster there!! Love how it turned out!
    Stogy and SilverJimmy like this.
  2. cornfieldcustoms
    cornfieldcustoms
    Thanks for the kind words everyone. Its pretty but never to pretty to race
    The 39 guy, Stogy, saltflats and 2 others like this.
    I don’t know if the record is soft, but it looks pretty old. You bringing it to ElMo?
    Stogy likes this.
  4. Stan Back
    Stan Back
    It may look soft, but with Jack Kelly's name on it, it may not be.
    The Bonneville record from 2021 is 166 with more than double the distance.
    51504bat, SilverJimmy and Tman like this.
  5. jimmy six
    jimmy six
    Jack Kelly set that record in a 34 Ford that was stock height in the rear with a point nose. The flathead was injected and used a 39 transmission. If this new one comes to El Mirage and doesn’t run on or set the record I would be very unhappy.
    Speaking from many years (40+) of El Mirage, Muroc 3 times, and Bonneville this roadster will never be as nice as it is right now. The craftsmanship and dedication shows in spades but if it isn’t taken apart to every last nut and bolt there will be salt or dirt you can never get out. Its just the way it is…..but it sure wouldn’t stop me putting it on any LSR venue.
  6. y'sguy
    y'sguy
    from Tulsa, OK
    Turned out just beautiful. Hope I get to witness it make some runs. I know you have an engine in it but is that the race engine? Look forward to see what you come up with.
    Stogy likes this.
  7. cornfieldcustoms
    cornfieldcustoms
    i plan to fully dis***emble the car every season and clean and inspect it.
    i have the current “race “ engine in it. It will be used to dial the ch***is in and see what our speeds are. Then add more power where we can
  8. jimmy six
    jimmy six
    Stogy likes this.
  9. pprather
    pprather
    The car is even better looking in person. Sorry I wasn't able to introduce myself to you today, Mike.
    The 39 guy, Stogy, y'sguy and 4 others like this.
  10. cornfieldcustoms
    cornfieldcustoms
    Thanks man. If your around today and see me please introduce yourself
    Stogy likes this.
  11. pprather
    pprather
    Sorry, this is a one day event for me.
    I'll have to see you down the road.
    Stogy likes this.
  12. cornfieldcustoms
    cornfieldcustoms
    Got the car up on scales to work on CG/CP balance. Initial numbers are pretty decent and less over all weight than I predicted. Going to add 100lbs to the nose and recheck 2AA2151E-AB71-49CC-943D-B898A6FF2C33.jpeg 0D333436-96B3-4D6E-8620-6A4F4F4AE58F.jpeg
    Stogy, NoSurf, RatPwrd and 3 others like this.
  13. Stan Back
    Stan Back
    Front to rear -- 40/60 is a good balance.
    Was there a driver in the seat?
    Stogy likes this.
  14. cornfieldcustoms
    cornfieldcustoms
    Yes it was race ready with suited driver
    Stogy and Kelly Burns like this.
  15. Stan Back
    Stan Back
    Here are a couple of charts you might find interesting. The car is a loveable brick, but it did set 7 El Mirage and Bonneville records.
    Stogy likes this.
  16. cornfieldcustoms
    cornfieldcustoms
    I cant get it to open
  17. 51504bat
    51504bat
    Its a PDF file
    Stogy likes this.
  18. tomcat11
    tomcat11
    I have been quietly following this build from the beginning and have to say this is one of my favorite threads on the H.A.M.B. The engineering and fabrication is master cl***, as is the creativity of the builder. Packaging all of the systems that are required in such a compact car takes an incredible amount of fore thought.
    The color scheme is flat out stunning with the gold ch***is, polished scallop, paint, and lettering. The blue headers are a really nice touch as well. The final scale weights show the true comprehensive nature of this build.
    Many Kudo's to Cornfield Customs, I am profoundly impressed!
    The 39 guy, Stogy, Ken Smith and 2 others like this.
  19. cornfieldcustoms
    cornfieldcustoms
    Thank you. I am humbled at responses like this
    Made a ballast tank to hold some lead shot for inside the nose. Added 200 lbs and was able to get the balance to 47.5/ 52.5 and 2891 lbs fully dressed
    Now that the car is about wrapped up i need a trailer to move the car around on the salt. So i am designing and building an air bagged trailer to lay flat for ease of loading. CF7C0FE0-51CB-4DE3-9703-57023F9AADB5.jpeg 044E4731-18E4-487B-8C3D-74B89A8A85F3.jpeg 01713613-A92C-45AA-AC61-C58868A8FECF.jpeg 83C4D468-7BA6-482D-9B5C-57C597FCC8E2.jpeg 8E4E4BF4-AB9E-4829-98BC-6989584D8E30.jpeg 6DC9F0E9-78C2-4682-8987-2B366EB822B3.jpeg 2FEFAB6A-D37D-48BC-B3C4-63E273A91906.jpeg 30A34C55-FFD8-47E0-873C-6D1B4F00CF9A.jpeg 0AFDF74F-6146-4679-9BE1-16F92DBC8009.jpeg 4037EBC0-2FB8-4B45-9361-D6458B051BDC.jpeg 51DB3CC7-510F-4DDE-9107-B9CBF0E0A990.jpeg 1D0060EA-FC91-43C8-9707-DEDB30191F3B.jpeg 54B2018D-F0E0-4517-B37E-1A8F86E9DE79.jpeg
    The 39 guy, Stogy, tractorguy and 7 others like this.
  20. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Incredible talent! You Sir, are Bad A$$!
    Stogy likes this.
  21. 51504bat
    51504bat
    Is it big enough for all the tools and spares or is it just for the car? Regardless it's going to be ***s.
    Stogy likes this.
  22. Many teams build a trailer like this just to move around the Salt instead of flat towing, Streamliners and lakesters especially. Trust me, if you ever spent 45 minutes steering a roadster from the far end of the course back to the pits on a strap you WILL get it!
    Stogy, Calkins and 51504bat like this.
  23. cornfieldcustoms
    cornfieldcustoms
    This one is just for the car but will fit inside my enclosed with the car on to and haul it all out in my big trailer
  24. Calkins
    Calkins
    Mike, are you going to add a fire extinguisher mount(s) to the trailer and/or push "bar" on the truck?
    Stogy likes this.
  25. cornfieldcustoms
    cornfieldcustoms
    Plan is on the push bar
    Stogy and Calkins like this.
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Do you care to tell us about the push truck? Is it HAMBy?
    Stogy likes this.
  27. Have you planned on adding a canopy/shade system for the long lines on the long course? Like the BlowFish and Eddie Umland’s trailers?
    Stogy likes this.
  28. jimmy six
    jimmy six
  29. Its still a ton of wear and tear on the car, especially at Bonneville
  30. Calkins
    Calkins
    13900145_10154482385414468_9216782351074276503_n.jpg 13902645_10154476382759468_7753644101500967120_n.jpg 13906638_10154476385539468_5937633616149304905_n.jpg 13912685_10154482384929468_1225126283196016796_n.jpg 68368706_10157516655514468_2789739932023783424_n.jpg 68542635_10157527081209468_8983893671271202816_n.jpg
    Stogy, y'sguy, alanp561 and 2 others like this.
