Event Coverage Bonneville
Discussion in 'The Hokey Ass Message Board' started by birdman1, Mar 29, 2022.
  1. birdman1
    birdman1
    I'm thinking about going to the Bonneville flats this September to run my 1937 ford coupe with the Lincoln 430 motor. I looked at the rules and safety requirements, looks doable. Can someone that has been there tell me what to do to be able to run? Thanks for any help.
  2. Ebbsspeed
    Ebbsspeed
    Order the rule book from the SCTA.
  3. Pete1
    Pete1
    from Wa.
  4. aircap
    aircap
  5. You are talking about the USFRA World of Speed 130 Club?
    https://www.saltflats.com/
    Contact them. If not this event you really CAN NOT run a hot rod off the street on the Salt without a lot of money and changes for safety.
  6. Mike VV
    Mike VV
    from SoCal
    They are pretty strict with the rules, so don't do any "skirting", the first time that you show up !
    Find and verify the cl*** that you will be running with an email, or phone call. And again, stick with the cl*** AND the safety rules.
    Mike
    Algoma56 likes this.
  7. birdman1
    birdman1
    looks like i'll be a spectator ! But i sure would like to know how fast that 430 would push my 37 coupe to. I have 6 carbs and a 428CJ grind on the cam. guess I;ll have to do it on the highway! LOL. thanks for the help. IMG_20211130_132010626_HDR.jpg
  8. Jalopy Joker
    Jalopy Joker
    yep lots of rules & regulations, and deadlines to be met - but, experience of a lifetime.
  9. You could still run that in the USFRA 130 Club. go to www.saltflats.com To contact them. It is set up for folks with street cars to get a chance to experience racing on the salt
  10. 38Chevy454
    38Chevy454
    What you want is the Utah Salt Flats Racing ***ociation (USFRA) www.saltflats.com and run the 130 club. Just ensure your car has the required safety equipment as needed. Go and have fun. USFRA is 1 mile only. Basically a 1 mile acceleration test of your car, on a limited traction salt surface, with an equivalent air density around 5000 ft or so.
    Your car can do the USFRA. It can't do SCTA Speedweek or similar that use SCTA rules. At least as it is set up now, you would have to do major work and add serious safety equipment to run SCTA. SCTA is not what you want for a street car.
  11. saltflats
    saltflats
    from Missouri
    130 club isn't hard to qualify for.
    Need speed rated tires and metal valve stem caps.
    Tman likes this.
  12. birdman1
    birdman1
    I am going to look into it, thanks
  13. "Wally"
    "Wally"
    Nice ride! I would suggest bringing it to Speedweek, Aug 6-12 this year, not to run but to check it out. If you have never been just driving around in your ride and visiting with folks would be well worth it. You'll learn a ton. If you go be sure to visit our pit or talk with us at the start line line up. Were easy to find, just look for the Fire Truck hauler or car #426 Flying Rose Racing. The Hauler.jpg ]ATTACH=full]5394518[/ATTACH]
    chryslerfan55 and harpo1313 like this.
  14. jimmy six
    jimmy six
    130……maybe…..your pushing a brick with a little aero thrown in.
    I guarantee your a** will pucker if you ever hit 150…it is going to lift…been there-done that….never again.
    Tman and Stan Back like this.
  15. Mr48chev
    It rather makes you wonder how many guys actually show up at Speedweek every year thinking that they are going to be able to go out and make a full throttle p*** in their street car.
    I've probably had a half dozen guys tell me that they were going to take their car to speedweek and run it and each one gave me a blank stare when I asked what cl*** they were going to run in and how long they figured it would take to prep the car to race in the cl*** it fit in.
    First step for racing at Bonneville in any ***ociation is to get the rule book and study it.
    For the USFRA 130 club the rules are here https://www.saltflats.com/I30_Club2015.htm
    A sample copy of the 130 Club tech inspection sheet here for personal use. https://www.saltflats.com/Forms/130 INSPECTION FORM 2012 web.pdf
    Just a side note, as it sits that 37 most likely would run in the B/GC = B Gas Coupe cl*** with a 237.05 record.
  16. jimmy six
    jimmy six
    Mr48….yep with somewhere between $3-5000 it MAY be able to make an SCTA p*** and get a timing tag. Bonneville is not in the 1950’s anymore and with someone with a short wallet. I’m glad I started in the early 70’s.
    deucemac and Tman like this.
  17. And we all know even a high end Streamliner team was turned away from Tech a few years ago when their tubing did not meet the new Spec. The car never came back to the Salt.
    jimmy six and chryslerfan55 like this.
  18. aircap
    aircap
  19. deucemac
    deucemac
    If you are dead serious about running, before you d anything, get a rule book. You can order on SCTA-BNI.org. then call Jo Ann at THE SCTA headquarters and find out in any SCTA inspection people live anywhere near so that they might look at your car and let you know what you need to do. It's an awful long tow out there to dissapointed because the car isn't up to snuff. THE SCTA is strict but also has one of the best safety records in all of racing .
