920011 Borgeson steering box in my '40 pickup. A Borgeson 525. A Vega steering box mount is suppose to be the correct bolt pattern. Has anyone installed one of these in a 40 Ford and use the stock steering column? What joints were used to connect to the stock column shaft? Or was it replaced? I cut the shaft to remove the original stock box out of the frame.
Here's the complete kit. Give them a call and I'm sure they can answer your questions. https://www.weedetrstreetrod.com/ecommerce/steering-upgrade-kit-for-1940-ford-w-axle-front.html
Thank you, Im in the process with him. I used their delete x member kit 20 years ago , split wishbones.
