Technical Borg Warner R10 ID help
Discussion in 'The Hokey Ass Message Board' started by 61Tudor, May 7, 2017.
  1. 61Tudor
    61Tudor
    I have just aquired a Borg Warner R10E-1 ****** and am having trouble determining what it was originally installed in. Solenoid indicates Studebaker/Nash (4AR10B-62). My problem is actually with the bell housing. It will be going into a 52F1 and want to retain my current clutch setup. I believe I need the "hogs head" bell. Is there a chart showing the bolt patterns on the front of these ******s? Input shaft is also different from the other Ford stuff I have.
    Thanks,
    Gord
  2. 61Tudor
    61Tudor
    A little more info, Input shaft measures 6" from ****** face to the end. 1" -10 spline input shaft. Pilot shaft is .665", 4 bolt pattern, 5 1/4" across the two top bolts, 6 3/8" across the two bottom bolts and 7 1/4" from top to bottom on the right side facing the ******. Flange that locates the ****** in the bell is 4.658" Diameter.
  3. 302GMC
    302GMC
    from Idaho
    Take a picture ... it'll get you an ID in minutes.
  4. tinsled
    tinsled
    R10 does not bolt to clutch bell housing, but to 3-speed gear box end. B&W made R10's to different housings for different makes. For example in below; top one is for Studebaker, middle is Dodge (seen from below, drive shaft flange on left) and 3rd for Ford truck. As you see, the unit lenght is different for different makes even if the planetary unit is the same... Thus these are NOT interchangeable over makes.
    An important issue is also the lenght of the reverse lock rod. (From 3-speed to the OD unit).
    ... one more, Mercury unit exploded view.
    Here you see ONLY the B&W R10 OD unit, the Mercury 3-speed not illustrated.
  5. 61Tudor
    61Tudor
    Here is what I have! IMG_0130.JPG IMG_0131.JPG IMG_0132.JPG IMG_0133.JPG IMG_0134.JPG IMG_0135.JPG IMG_0136.JPG
  6. farmalldan
    farmalldan
    from Duncan, OK
    Looks like '49-54 Ford to me. I think this transmission was replaced by the BW T-86 about 1955. P***enger car bellhsg from '49-53 Ford should allow it to bolt up to your flathead. Clutch and rear mount issues may have to be dealt with.
    Farmalldan
  7. Mac VP
    Mac VP
    The black trans in your pics is a regular 1949-50 Ford p***enger car overdrive transmission (non convertible). The 3 speed portion is the regular Ford 9 bolt side loader and the overdrive section is the Borg Warner R-10 overdrive unit. The BW section is pretty much designed for the specific vehicle ch***is, even though a number of internal parts are common across all the R-10 overdrives.
  8. 61Tudor
    61Tudor
    Is there a bellhousing this will bolt to that lets me use the truck pedal and linkage or am I getting a car bell and switching to a slave?
