Technical Borg Warner spares (planatary gears)
Discussion in 'The Hokey Ass Message Board' started by Reidy, Jul 25, 2025.
  1. Reidy
    Reidy
    A few years ago I purchased a, what I think is a Muncie 319 with the Borg Warner R10 overdrive in supposed good working order, he apparently only removed it to put in a T5.
    I stripped it down today to give it a freshen up before use and my opinion of good working order is a bit different to the sellers.
    This is what I found.
    Is there a supplier that has sun and planetary gears, or has anyone discovered a setup using gears from an automatic that are easily available. I am Australian based but will be surprised if I don't have to buy from the states.
    Thanks for any help
    Steve
  2. miker98038
    miker98038
  3. Reidy
    Reidy
    Thanks, I will try them.
  4. Van pelt probably has em.
    More than likely used.
    Most of the r10 set ups seem to share the same parts beteeen makes. Output shafts being brand specific.
    squirrel likes this.
  5. Mac VP
    Mac VP
    At the moment we probably have 3-4 nice good used planetary gears in stock, and plenty of nice used sun gears. It’s impossible to tell from the picture whether the freewheel cam ***embly is still okay or not. It needs to be removed from the planetary gear (remove the U clip) then cleaned and inspected. Good freewheel cams are just about as hard to find as good planetary gears. If you’re in Australia just shoot me an email inquiry (sales@vanpeltsales.com).
  6. Reidy
    Reidy
    Thanks Mac VP, I will strip it a bit further, clean, and take some photos and put it all in an email.
    Much appreciated Steve
    vtx1800 likes this.
  7. Mac VP
    Mac VP
    Try to keep the freewheel cam ***embly together as you separate it and handle it. Although it’s more difficult to clean when ***embled, it can be VERY difficult to re***emble the inner hub and the two springs if you let them separate from each other.
  8. Reidy
    Reidy
    Thanks, I have sent you an email. I guess I will get to test my skills, as the photos below will show what I was doing when not on HAMB. When I was much younger I had fairly good hand skills working on F111 aircraft instrumentation. These days the eyes and finger are not as great as they were, but I am sure if I preserver I will get it back together. 1000007129.jpg 1000007132.jpg
  9. Reidy
    Reidy
    MacVP, after I replied I went straight up to the shed, at least it was only 5 minutes and it is all back together. My lucky day. I can relax now and keep catching up on HAMB.
    patsurf likes this.
  10. Mac VP
    Mac VP
    To address the question of the condition of this freewheel cam, the photos of the two parts show two things. The inner hub appears to be in pretty good condition. The “ramps” (the surface where each roller bearing moves in or out) are still pretty smooth. When they are worn badly you’ll see galling and erosion into the steel surfaces. When that happens the roller will settle into the “slot” of wear and fail to move outward fully……and that means the 12 rollers won’t move outward enough to drive the inside surface of the gear and mainshaft that they live in.
    The outer shell should still maintain its round shape. If it’s been bent it can create ***embly and operating problems. I do see some “hammering” wear on the edges of the 12 rectangular slots for the roller bearings. I clean this wear up by running a fine tooth steel file over the edges.
    For folks wanting to dis***emble these cam ***emblies, take some photos of the unit….noting the direction of the external spring ends. When you’ve got it dis***embled, look at the locations of the little holes in the hub and the outer shell. Each component will have a hole higher up than its opposite side. It must go together back the same way.
    patsurf likes this.
