"Boring"283 question
Discussion in 'The Hokey Ass Message Board' started by Scott, Dec 7, 2005.
  1. Scott
    Scott
    I have 283 block that probably wont clean up at 60 over,My question is can this block be bored to a 4" bore and built as a standard 327 or 302?
    Thanks
  2. this has been discussed before , and i have given my opinion ,which is sometimes different than others on here!
    it depends..with core shifting during the original casting process and 40+ years of rust , the only way to know for sure is to have the cylinder walls sonic tested. then there can be a deep rust pit that doesn't show up in testing. some years blocks are susposed to have thicker walls , but no one seams to agree on what years
    my opinion is boring a 283 to 4" is a **** shoot
    read what RACEFAB says in this thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=62753
  3. lowride
    lowride
  4. BOBCRMAN
    BOBCRMAN
    from Holly
    Been boring them since the mid sixties, MOST will go 4" but there is always the exception. Some, due to core shift, air bubbles in casting, sand pits, will not.. Sonic testing is the only SAFE way to go. Also be sure the cam bearing bore is well centered with the machined face. :D
  5. Deuce Roadster
    Deuce Roadster
    :eek:
    Like said above .....YES & NO.....
    I have done it with no problems ........long before sonic testing was available.....and I had one crack a cylinder wall and get water......riding down the road with my mother in the car....... ( I was 17 and it was 40 years ago ). You know I was driving very safely and NOT turning the 301 up :)
    I would not invest the money.......it is mostly a ****shoot. SBC blocks are too inexpensive to come by.....unless you have a rare matching number situation or some other attachment to that block.
    I bored my last 283 ...just 60 thousands....I had a set of NOS sixty over Corvette FI pistons....
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If you are going to attempt it, the '58-'62 blocks are supposedly the best bets for a 4"bore.
  7. 38Chevy454
    38Chevy454
    Are there such things as .080 over 283 pistons? Or is this a cu$tom pi$ton order? Reason i ask is that I already have a 283 that is .060 over and worn out. Just wondering if I can do a cheap rebuild on this engine or time to look for a less-used block?
  8. JasonK
    JasonK
    Put that poor thing to rest..... :eek:
  9. 5foot2
    5foot2
    from Maine
    This is the perfect block to try a 4" bore on. If I owned this I'd try the .120 over and see how it went. If it fails your not out to much.
    If I had a block that was std. or just .030 over I'd just clean it up with .030 over the existing bore.
  10. ENGINENUT
    ENGINENUT
    Before factory 4" blocks were readily available (junkyard) it was common to go to 4" with 283 and I have personally used a 265 with .155 overbore.If sand holes or flaws are found in 1 cyl a sleeve will cure that with good reliability.I s****ped a 63 327 planned for a Corvette when 3 cyls showed a flaw, and we only wanted to bore .030 OS.I have done quite a lot of cylinder preparation over the last 45 years and I feel like the early sbc used a very "soft" (cheap) alloy compared to Buick,Chrysler "slant 6", and Cadillac, but later engines seem to have much better cylinder life.Early 327 and 307 the worst.A later 4 ncher should be a longer lived block and a better risk of soundness.
  11. 38Chevy454
    38Chevy454
    You are right, but this is a 66 block. Supposedly the later blocks are not as thick cylinder walls? Guess a sonic check is the way to tell for sure. I had always thought of getting a decent 327 small journal block and build my 4-inch bore engine from that.
  12. BenD
    BenD
    Alliance Member
    I've got the same thing with a '57 block. If anyone needs another I'd be happy to let this one go for cheap.
  13. Don't forget if you tap the block out too much you can run into the problem of having the engine run alot hotter........maybe too hot for basic street use............hope it works out.
  14. 48fordnut
    48fordnut
    In the 50's i ran a 283 bored to 4'' in a dragster. I don't know about longevity or running hot, but we went thru blocks at the rate of 2,or 3 a yr. I have a similiar eng now that is poured, to the top and won't run water in a fed. You can get too big on the bore and the wall won't be able to get rid of the heat,in a street application.
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Ebay item #8019946667; a set of .155 oversize 283 pistons, for the adventurous.
  16. SnoDawg
    SnoDawg
    Hey ENGINENUT You sound like a pretty Knowledgable engine Guy How about posting an intro??
    Dawg
  17. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Ebay item #8022435735--new .080 over pistons for 283.
  18. 1gearhead
    1gearhead
    Like the man said if there is minimal core shift and not too much rust erosion (sonic testing will tell) bore to 4" throw in a set of 327 pistons and some cam and this little 301 will rev like hell. No bottom end torque, but we used to wind these motors to 7000 - 8000 RPM. Watch out though when the cylinder wall cut loose as they ****tered pretty quick.
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    302 pistons, yes. 327 pistons, no. The 1/8 inch difference in compression height won't do much for compression.
  20. ENGINENUT
    ENGINENUT
    Did just that Dawg, Thanks for asking.
    ENGINENUT
