Botched Chop Job 30 Ford Coupe
Discussion in 'The Hokey Ass Message Board' started by pottsie454, Jul 1, 2012.
  1. snelson57
    snelson57
    Nice...this was exactly my thought at the start of this thread. I knew it wouldnt take long for a Hamber to step up. That is a great offer.
  2. Bruthish
    Bruthish
    This place was given "mad props" and so far its true. Very awesome of you guys to offer ***istance and parts to help us get started! Guess I found a new home :)
  3. RagtopBuick66
    RagtopBuick66
    There is some CRAZY talent on this forum. You have definitely come to the right place. I'd look at that body and walk away, where some of these guys would look at it and ask "What time tomorrow do you want to have it in paint?"
    Unbelievable knowledge, a billion years worth of experience, and 99% of them hearts of gold. Most of 'em won't ever ask for a thing in return other than that you help someone else down the line if it's ever within your ability to do so. If THESE guys can't help you, you're ****ed. If I could buy them ALL a beer I would. Welcome to the H.A.M.B.
  4. jazzbum
    jazzbum
    i think it's fixable (that is, i've seen worse actually driving down the road) although it's a job that would be beyond my skill set. if you're a good enough fabricator/metalworker, i think you could make the pieces you need without much trouble. i would probably try and even out the cut lines first and then maybe add material if it has the lid sitting too low. but again, i'm pretty much talking out of my ***. i'm not even sure why i'm making this post.
  5. maybelene
    maybelene
    This is how i would go at it too. You can fix it, it's just going to be a severe chop when finished. It's just metal and can be reshaped with a hammer, dolly, torch, and welder. Get it squared up and fill in with small pieces of metal cut with a jigsaw. Kirk's right, posterboard makes great patterns. Keep the patience.
  6. pottsie454
    pottsie454
    Well I'm not willing to give up on this thing. With patience and time I think I can do it. With your guys help anything is possible. Thanks for the advice and I'll keep you posted on how we are coming along.
  7. shane85
    shane85
    cool man. my chop was also bad i am still trying to fix it. I got a coupe because i wanted a coupe not a roadster. you can fix her its just time,money,parts,
  8. It can be saved. It kind of reminds me of the Green Grenade?
  9. shane85
    shane85
    very true
  10. adam401
    adam401
    That chop is not a bad fix. The roof filling attempt might be easier fixed with the replacement panels that they sell for over the doors though. Id make sure the body and roof were parallel then mask off right over the exising cuts with 1" masking tape and mirror cut the body and roof. Then Id weld that ***** up and rock it. I like a nice hard chop though. Donor roof is for pussies
  11. metalman
    metalman
    Man, what a mess but you don't need a doner roof. The extra posts, ect someone offered would be a big help if you want to raise the roof up a bit and square it as you go, flat strips welded around the back fixes the bad cut. It almost looks like whoever cut it took those cartoons of a guy chopping with a chainsaw to heart!
    The window corners can be fabbed easy enough. After seeing this I spent 10 minuets with a bead roller and shrinker/ strecher and came up with this (I have a 31 coupe in the shop I used for the pattern. It would take a little longer but you could form it with hand tools. Or PM me, I'll make you a set, cheap.
  12. shane85
    shane85
    very cool.
  13. pumpman
    pumpman
    Glad to see you guys have the stones to take this on a save the old girl. You came to the right place for help and advise, so have fun, make mistakes and take time to have a beer and laugh about what just happened. Good luck and remember it's just metal so **** you can do it.
  14. fts55
    fts55
    from guthrie ok
    Save it 100%. The one's telling you to junk it are just untalented and jealous. Why does everyone keep saying to get a donor roof so thatyou can unchopp it? I think the amount of chop on this car looks *****ing. Just fix the bottome, gather up the pieces, and then fix the chop and the window. Just keep you head down and get it done.
  15. ironandsteele
    ironandsteele
    that's probably the worst i've ever seen.
  16. mopar210
    mopar210
    these are nice window corners , also have you looked at SNYDERS MODEL A AND T PARTS ? they have the new cowl panels , rear inner fender panels and new side roof panels and much more . when i built the 29 , i used a bunch of parts from snyders and was very pleased . you can almost build a complete car from these guys , of course i was lucky , its only a 30 minute drive from my house to snyders , look them up on line . todd
  17. six pack to go
    six pack to go
    from new jersey
    First step, get off the HAMB and get to work... post the results in a year or 2!
  18. hooliganshotrods
    hooliganshotrods
    Wow, that is a horrible chop some guys just shouldn't even touch tools:eek:.
    It's a coupe, good on you for saving it. It can be fixed with some metal work and patience. Good luck with it.
  19. no one has mentioned coupster ... gee model A's with good roofs are every fricken where ... keep lookin save yer beer money for two weeks
  20. rats28
    rats28
    from Louisiana
    I might have some pieces left over from a chopped coupe you can have just let me know what ya need
  21. The generosity never fails to amaze me . Well done Lads!
  22. Bruthish
    Bruthish
    Here is a couple of shots of the A pillar posts and one of the driver's B pillar. Workmanship is incredible!
  23. pottsie454
    pottsie454
    Metalman - that's the **** man. What brand bead roller ad Shriner/stretcher do you use or recommend. I'd like to give it a try and see what I come up with.
  24. metalman
    metalman
    I use a Mittler Bros. bead roller, I love it. I have their standard 15/32 tank roll die, it rolls 1/2 the radious so if you look you'll see I made the corner in 2 pieces, then welded them together. Not only does it happen to make perfct size early Ford window frames the same die turned around will make perfect body reveals for them as well I found out! Of course the outside ridge is just an 1/8" step die. Very versitile machine, today I'm using it to put a wire edge into a set of 1912 Stanley Steamer fenders I'm building.
    I use a 20 year old Eastwood shrinker/ strecher, has served me well.
    Invest in a couple good tools like a bead roller and the shrinker/ strecher and you won't have to spend money buying patch panels ever again, little pratice and you'll find yourself making them all!
  25. hooliganshotrods
    hooliganshotrods
    I have the same bead roller and I love it though a bigger motor would be nice. That mixed with an English wheel and a shrinker stretcher and you won't be buying patch panels every again.
    Nice job on those little corners you made, just shows how quick a patch can be made with the right tools.
  26. kscarguy
    kscarguy
    Dang Metalman, I might have a job for you...I've been struggling with the design of latch handles for the storage boxes on my COE. Maybe you could take three and a half minutes and build them for me? :)
  27. bangngears
    bangngears
    from ofallon mo
    Look at it this way,whatever you do to it,it will only get better and you get OTJTraining.Pleeeeease get the Mustang front off also.
  28. fbama73
    fbama73
    Props to you guys for tackling one that's just on the outer edges of your skill set. It might be a little bit rough, but it's definitely salvagable.
    And props to you guys offering help in the way of stuff that most people toss away. I stripped a 51 Chevy door that was WAY past roached out of everything I could imagine someone using. Even cut off the entire window frame. Sooner or later, someone will make a mistake during a chop, and that window frame will save their ***.
  29. Terrible Tom
    Terrible Tom
    Nothing like a challenge to get you going. Yeah, it's a hack job, but as others have said, you can fix it. Just take your time, straighten up those cuts, top and bottom and go from there.
    Kudos to all you guys who offered parts. That's really nice.
    Tom
  30. MODELAHEMI
    MODELAHEMI
    Mabe advertise for someone who did a model a chop 4'' or more and saved the cut sections. Rechop and work them into the top and body.just add what what you need.i still have the sections i removed somewhere.there are 4".my buddy has some off his a bone 5.5''.
