Projects Bought a Mercury on purpose
Discussion in 'The Hokey Ass Message Board' started by anthony myrick, Feb 4, 2023.
  1. When doing an electric trunk latch release, I've been mounting the electric part on the Body side and the catch to the Trunk Lid. Keeps from running a power wire past the hinge system. On the other hand, I like using a Morris type cable to the Stock latch and having no electric at all. A cable is more forgiving over the years than wires. Just food for thought.
  2. I’ve got a NOS cal custom remote release kit
    Also might use and extra door lock I have and use it to open the truck. Just have that single stainless lock on the trunk
    bchctybob, porkshop, 1low52 and 2 others like this.
  3. I like things that are mechanical over power ***ist.
  4. Moriarity
    Moriarity
    SUPER MODERATOR
  5. DDDenny
    I know what you're thinking Mark............
    "I have this pair of old swap meet valve covers and I think I'll make a set of air scoops for that Man-A-Fre intake on my Corvette".
  6. IMG_9691.jpeg Experimental
    Using this broke one as a test
  7. The 3.75 round fitters are a tight squeeze but still could be used
    wonder about some kind of filter like this could be adapted
  8. bobss396
    bobss396
    anthony myrick likes this.
  9. ffr1222k
    ffr1222k
    Your students have done a great job on the lights, front and rear. I know you are proud of them and their work.
  10. Squablow
    Squablow
    Valve cover scoop idea is interesting, I think it could work. Would be curious to see what they'd look like if the opening area was more of an arc instead of straight up and down, but the bolt hole bosses might make that tougher.
    Mine had been finned oil filters with the tops cut off.
  11. We’re gonna slight arc the front
    Just cut straight god now. The blog hole will be gone
    porkshop and Squablow like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
  13. On roughed out bases
    We’ll get em level and squared before final t*******
    The middle one is the prototype
    Have another
  14. Clydesdale
    Clydesdale
    Hmmmmm if only you had a shrink ray, if they were 1/3 smaller in scale they could be cool.
    As they are, to my eyes, they look too big and clumsy. I like the idea though!!!
    porkshop likes this.
  15. ekimneirbo
    ekimneirbo
    from Brooks Ky
    A suggestion..........You might consider a one piece mounting plate for all 3 carbs and then have some countersunk screws entering from the bottom of the plate to either brackets or individual plates inside each cover. That would allow the mounting screws to be concealed (torx or allen head) and once the holes are drilled properly in the plate, the covers would always be in alignment.
    The plate could have holes to slide over the carbs and small round flanges that use a simple "set screw" to hold it in place. :) If these don't work out the way you plan, they might make some neat custom wheel chocks. :p:D:D:D:D:D
  16. Gonna use separate bases. Probably stagger em up some from front to rear
  17. 38Chevy454
    38Chevy454
    I like the creativity. My suggestion is a little more space between them. I.E. little less length on each.
  18. bobss396
    bobss396
    Generate a radius across tye fronts perhaps. Combined with what you did on the prototype. They need to be a tad shorted, front to back.
    ffr1222k, bobss396, Squablow and 3 others like this.
  20. bobss396
    bobss396
    Getting there... I was talking about a radius in the front plane, viewed from the top. Trace a 40 oz beer bottle bottom over it.
  21. ididntdoit1960
    ididntdoit1960
    from Western MA
    Did you think about using one cover open at the front for all three carbs? Kinda like an early Hilborn style scoop.
  22. We plan to make square individual filters with a stainless mesh for each one
  23. bchctybob
    bchctybob
    I would trim off the gasket flange on the sides so they don’t look like pieces of valve covers. And match the curve of the front cut to the curve of the back. Just me….
    Clever idea.
  24. Almost getting too short to put a filter.
    Plan on using the flange to mount it without having a bolt thru the top
    gonna work on that curve some
    Squablow and warhorseracing like this.
  25. riv63
    riv63
    from Texas
    Anthony, could you angle them to expose more of the opening?
    Squablow likes this.
  26. Probably will stagger them up a tad
    bchctybob likes this.
