Bought an old shop compressor today..
Discussion in 'The Hokey Ass Message Board' started by Reman, May 21, 2013.
  1. Reman
    Reman
    from Florida
    to use on my old car junk. I could tell before I bought that it would need an overhaul.I started looking for parts and cannot find anything on the internet. Is anyone familiar with "Hercules" air compressors? The only tag I find on the pump simply says Hercules...5HP.....Louisville Kentucky. Can anyone shed any light on this thing for me, or where to look for parts? Thanks!
    Well now I guess I have forgotten how to post pics.
  2. Hefty Lefty
    Hefty Lefty
    What kind of motor does it have?
  3. lango
    lango
    from Georgia
    Check out the Garage Journal. They have a forum that deals with old shop tools, specifically. You'll probably get the info you need- good luck wit it.
  4. tb33anda3rd
    tb33anda3rd
    what is it doing? or not doing?
  5. joe--h
    joe--h
    from New Mexico
    Why does it need an overhaul? If it's not been run out of oil not much goes wrong with compressor except for the reed valves. Have you taken it apart? What does it need? For sure any compressor shop you call will tell you it's junk, you need a new one.
    More details please. Joe H
  6. I have a couple of old ones. They are easy to mess with. Pull it apart, and hot rod it. Lol. Any chance of a few pics? That would help.
  7. I recently picked up an OLD IR 5hp V-twin compressor with a newer Leeson motor. Mfg date on the tank is 1948! Same exact pump they are using to this day. $200 vs. $2100 for a new one.
    Never heard of the Hercules, but I doubt it's junk.
  8. Tnomoldw
    Tnomoldw
  9. Tnomoldw
    Tnomoldw
    They made engines I worked on one in a fire truck . Was a gas engine , The made diesels too , Military , and stationary engines . your compressor is prolly off a truck ,,
  10. Reman
    Reman
    from Florida
    Not sure on the motor. I will have to clean the plate better tomorrow. I think I could make out "DOERR".
  11. Reman
    Reman
    from Florida
    I am aware of Hercules engines, but never thought of them making compressors. I guess it could be off a truck, though it seems bigger than what a truck would have.
  12. Reman
    Reman
    from Florida
    Thanks. I will try to put up some pics tomorrow evening.
  13. Reman
    Reman
    from Florida
    and much prefer to rebuild antique cast iron stuff
    We think alike! LOL I paid $175. and much prefer to rebuild antique cast iron stuff than buy new stuff that has a predetermined life span.
  14. XxWingNutxX
    XxWingNutxX
    from Greer SC
    I work for a compressor company. If you can find a model and serial number I can probably find just about any part you need.
  15. Reman
    Reman
    from Florida
    It pumps up and cycles out fine. But it has some oil in the lines and not as much compression as it should have. I think the only way the oil could get there is p*** by the rings. I also think the bottom end is noisier than it should be. And yep, the shops would call it junk, but I prefer old stuff. And once put in good condition, it should last as long as I ever need one.
  16. Reman
    Reman
    from Florida
    Thanks. I will see if I can find further info tomorrow.
  17. Reman
    Reman
    from Florida
    Here are the pics.................
  18. dsiddons
    dsiddons
    from Indiana
    I know where a old Kennedy is in operating condition. I really want it bad. Super quiet and beautiful to. Good score enjoy..
  19. fsae0607
    fsae0607
    ^^ what he said.
    Looks bad ***!
  20. Reman
    Reman
    from Florida
    Yeah, I hadn't even thought of the pulley size. It does need to be much smaller. I'll see if I can find something more suitable.
  21. Reman
    Reman
    from Florida
    Its a 1725, though it doesn't sound terribly fast. I probably need to address that before I run it too much. Though there is no telling how long it has been set up this way.
  22. Reman
    Reman
    from Florida
    I suspect your theory is 100% correct. That is why I want to find parts to get rings and bearings before I set it up in a permanent place. But I am still finding absolutely nothing on the internet regarding Hercules compressors. I am going to go into the garagejounal as someone suggested and see if anyone there is familiar with it.
